Polaris in dash gps 4runner/hilux?
Hotdog
Paddler Ed
I have a 7 in Nexus with memory map so I'll be happy to hear a solution as I can't find a suitable place to mount it.
Is that can't find somewhere to mount it in a 4Runner/Surf? I've got mine (exactly the same tablet) mounted off of the front passenger seat rail bolt.
I've got an Arkon that holds it perfectly, $35 from a bricks and mortar retailer in VIC.
Got a longer 8.8 bolt to replace the original bolt on the RH seat mount that the Arkon is now bolted into (If I bolt something in I want at least the same length thread as was already there).
The mounting bracket has a number of holes in it so that you can mount it at 90* to the bolt slot/floor, even if it's at an angle.
It does limit forward motion of the seat, but it's not the end of the world as we pretty much use the car as 2 seater.
It has a good degree of flexibility in the arm, but is solid in terms of gripping the tablet; I've been running it for a couple of months now and it's been great, the tablet doesn't move, but I do have to watch it sometimes when I'm changing H2-H4-L4, but otherwise it's not a problem.
The GF has also found her phone fits perfectly so she uses it all the time in the car now!
