hi all hoping someone can shed some light on my situation . basically spun a big end bearing around christmas time last year so rebuilt my motor its a 1998 hilux 5L diesel . i had the bottom end completely rebuilt cylinder head was serviced had new exhaust valves fitted valve seat re cut and so forth , i also had the injectors and injector pump done , new radiator and clutch with machined flywheel . so far ive done 6000km all was going great until a knocking sound suddenly appeared one day , so far we have ruled out fly wheel the clutch and startermoter , i have also checked timing marks and everything is where it should be harmonic balancer appears to be fine as does the key way in the crank and cam , i have pyro temp gauge and up to this my egt weren't going above 500c' and that foot to the boards
that car isn't blowing any smoke or using oil I have found 1 metal shaving in sump so sump come off but nothing else was found all bearings appear to be fine no obvious play in rods or crank and can see any visible damage to the pistons . i have puller the valve cover off and everything is perfect in the head . engine builder said the metal was most likely contamination from assembly and not to be to concerned about it like i said it runs good starts first shot doesn't use oil or blow smoke it hasn't lost any power. It is just knocking and i am running out of things to check the knock sounds like a big end but as i said all bearings don't have any real visible damage the knocking sound does change when the clutch is pressed is goes a lot higher pitched but i have removed gearbox and clutch and the knock is still there .my only other theory is maybe its diesel knock but im doubtful because the tone of the knock changes with the clutch in .
can anyone shed some light on the problem like i said im running out of ideas of what it could be
thanks shaun .
thanks shaun .
