PK Ranger - Fitting new (secondhand) wheel tyres
Thought I'd post up the arrival of my 4 new (secondhand) babies for the 4B :)
CSA Jackals 16 x 8's +35 offset
Tyres are GoodYear Wrangler DuraTrac 265/75/16
Old tyres are standard Dunlop AT22s 235/75/15
A quick check of the rolling dia shows old = ~ 710mm, new 790mm, so a diff of around 40mm real lift from them.
Will do some pre and post fit measuring under the diffs and general body.
Offset, old = +25, new +35, so they'll stick out a fair bit more, but have at least 45mm in from the arches now.
Big test will be turning clearance, might have some 'adjustments' to make.
Can tweek the HD torsions up a little.
Also will have to watch downhill runaway, and will likely use LR a bit quicker than previous.
The ~ 8% speedo error will now be slightly the other way, but I use my GPS speed moreso now for driving on the road.
Before the fit up Wed, I'll take some before pics, then afters.
So, does anyone have advice as to if I need to get a wheel align ?
I'm thinking not really needed, but maybe a good idea anyway ?
I need to chase up another rim and tyre for a spare anyway.
mac_man_luke
Should look great and be a real improvement.
+35 offset means its actually closer in but the wider rims/tyres should mean you will be a little bit wider anyway.
Id say a wheel alignment is not crucial unless you play with your suspension but it never hurts, don't really want to scrub the nice new set of tyres.
Ta mate.
I'm really looking forward to seeing how much beeter the traction is, not to mention another 40mm or so clearance :) :)
Yeah, figure if I do wind up the torsions a bit, I'll def get a WA done.
I originally had them up 25mm to centre of bump stops, when new hd bars went in, they may have settled a little, not sure.
Sums for offset / tyre position is hard to do (at least at this time of day !), will likely just leave it and see what they're like on there.
I figured +20 in further, but not sure where the extra 40mm tyre width is going to go, maybe 50/50 ?
Thinking about it, they might come out from here they are now by 20mm more ?
80lover96gxl
Hopefully that offset wont have you scrubbing the inner guards on the rear, also on full flex in the rear touching outer guard, might need dome flares aswell but might just be ok I reckon.
phs
unsure on a ranger if it will rub but best place to look is inner guard steering / suspension components. If the tyres are 40mm wide you will be 30mm wider on the inner side of the wheel. you add +10 to your off set if you retained a +25 it would be 50/50 that's if your currently running x 8inch width rims
Paddler Ed
I use this site for working out clearances both inside and outside.
Quick pop through of the sizes:
Inner Clearance: 22.7mm or 0.87in less
Outer Position: extend by 2.7mm or 0.1in
Diameter difference: 2.77" (8.76%)
Hope that helps,
Ed
BTFIVO
Get a wheel alignment if you feel in pulling to one side or if you adjust the suspension in any way. Also, if you look very closely, you will see the outer flat on two tyres will have a slight more slope than the other two. Put these (sloped) on the rear and the pure flat on the front. They have about 2-3000klms travelled only. So about 5000klms, you would rotate them, may as well do it now.
I think they's be fine Les, they are huge compared to the current boots you have, won't affect runo-away too much and it will make 4x4 ratios more realistic as in 1st low will be a nice smooth pace. I found that the 295's were the limit on 4x4 very-steep hills, so the 32's will be good. I think you will enjoy them a lot. Bloody look great next to the rig.!!
They are looking the goods Les :)
Thaks fellas, yeah, think I'll be fitting em and seeing then, current rims are 6", so hard to tell really.
Hope that helps,
Ed
Thanks Ed, yeah a help alright, some good calculators there . . .
I came up with almost the same figure you did, which if right (old 6" rims vs new 8") will be about an inch further in.
We'll see how it goes.
Ok, I'll look for that and rotate.
Both diff oils and brake fluid flush / new fluid getting done Wed, so will slot new wheels on then and see how it goes.
Yeah, will likely get WA done anyway, just to play it safe.
Had one done not too long ago, with the small lift done already, it's almost out of adjustment, needs a shim removed RHS, but only 0.5mm or something like that, fixed any slight wear with rotations ok so far.
But, might be good time to wind the torsions a little if needed, and get a WA done proper.
Removing the shim is a real PITA job apparently.
Re your low range BTFIVO, gotta remember the later PX / BT50 has awesome downhill LR, the PK isn't as good with hill descents and runaway.
But, I can live with under 10% I think, just get into LR 1st and keep it slow.
Will also use LR a lot sooner on tracks, sometimes I just find there's no strain on things with the way it pulls so well down low, still a bit sooner now will be good.
Be testing this out a lot in a few weeks.
Ok, here's some stats, and pics . . .
Before / After (mm)
Ground to edge of wheel arches
LF 845 / 925 (wound up torsion to match RF)
RF 870 / 925
LR 912 / 940
RR 895 / 940
Under rear pumpkin 195 / 242 (an extra 47mm ! :D :D)
Slight scraping on full lock, both ways, both sides, on inside front of metal shroud panel, just needs a little hammer time :D maybe about 3mm or 4mm tops.
Used a 6mm spacer between front hubs and wheels.
Would have been better with 25mm or even 20mm offset, still well inside the guard edges.
No scraping anywhere on guard arches front or rear, if fact plenty of room.
(It has a suspension lift 25mm front, 40mm rear)
Going in for wheel align and balance Thurs, then a quick hunt for a spare, might just go new rim and tyre, same as.
Will check pricing and judge if worthwhile, or scout some wreckers out.
mac_man_luke
What width are the factory rims? if they are 7" rims then you could just stick a matching tyre on one of them.
Otherwise a black steelie should be less than $150.
Looks great, couldn't have got a better suiting rim looks wise.
Nah, 15" factory steels are only 6" rims.
Will keep these with the decent (at least 80%) AT22s for beach runs until worn out.
I'll likely just go a black sunrasia or similar, and run the same tyre on it.
Yeah, thanks, it does look a little better now :)
And it drives nice, only a little noisier (wa / bal might help with that) and the visibility is so much better, feels like I'm sitting that much higher for sure.
Diggings
Gooday Les. I am going through the wheel and tyre thing at the moment, my Wildtrack has 255/60R18 wheels and tyres on it and you cannot get a decent tyre to fit that rim, I am looking at going to 245/75R16 Black Sunraysia rims and STMax Cooper tyres, wheel and tyre are about $500 each with black centre caps. I cant go much bigger tyre size because of clearance when on full lock either way and I don't really want to fit a lift kit, I wound up the torsion bars a bit when I fitted the Bullbar an winch and I think that it is toeing out slightly now and will get an alignment before the new tyres. I want a decent tyre so that I can tow the van on dirt roads without any problems and cant afford to buy the wrong tyres.
Dave
Heya Dave, you probably can't go wrong with that setup, a good price.
You have the PJ / PK type Ranger, not the PX ?
If earlier PJ / PK, then offset of 0 or so should be ideal for that size, if going wider later (say 265/75), you could go +10.
I'm really happy withe the 16 x 8 rims, so much more versatility with ranges of tyres etc.
The GY Wrangler Duratracs are superb, was in Beurepaires the other day looking for a tyre gauge fitting, and asked about the current cost for the 265 75 16s, and was given a price of $365 ea fitted and balanced.
The ST Max are 50/50 off/on road, while the Duratracs are 70/30, but the aren't overly noisy, though certainly more than the old road like ATs I had.
Yes, would recheck your heights both sides and adjust finally to a happy height before the new ones go on, then have the W/A done.
Lordranger
Dave
Hi Dave, I have a pk and just went 265/75/16 sunraysia rims and pinnacle grizzly mt's, no rubbing at all without lift kit which is getting fitted next weekend.
Greasy_Efpv
I'm looking at some Mickey T atz p3s. 265 75 16s, on some sunnys. Mate has some 0 offset sunnys on his d22 and had to do a fair bit of bashing for clearance. Reckon the PK will be alright with zero offset and total diameter 804? Been looking everywhere trying to find someone with a pk and zero offset. I might just look around for some +10s or something
Greasy_Efpv
What offset is that with? I'm looking at +10 but 0 if possible, doubting I'll be able to get away with 0 though
