Firstly, let me say if you aren't sure your CAS (crank angle sensor) actually needs a clean, leave it be !!
What a bugger of a thing to get to / off / on again.
Anyway, from the 4WD Action forum, Engine & Driveline Diesel Tech section, thread on Engine Mapper Project page 23 http://www.4wdaction.com.au/forum/viewtopic.php?f=54&t=158437&start=330 the crank angle sensor was hit on a bit about how it's magnetic, and can get metal particles on it over time, giving dodgy readings.
Vehicle hard to start sometimes, like timing's out.
So figured along with a couple of other little jobs today I'd take it out and clean up.
Bugger of a thing, tucked away up between the exhaust dump pipe and a gazillon other things, ever a jap car assembly person would have a hissy fit doing this.
So you need a 10mm and 14mm socket, ratchet, mid extension, same size spanners, and a 1/4" drive thin cheap 10mm socket with small head ratchet or fixed bar. A really long extension around 6" to 8" might get the bolt easier from the front.
A bit of contortion is required, and sometimes best from behind the cross member, other times between the left axle and sway bar from the front.
So, after taking off the sump bash plate (4x14mm bolts), you remove a little metal heat shield on the bell housing, left side near dump pipe, (2x10mm and 1x14mm bolts).
The sensor is black with a 10mm bolt holding it in.
Here's a pic of the heat shield from behind the LH wheel, and the sensor from the front, both shots take from below where you'll be working, a couple of ramps or jack stands and raise 6" will assist greatly.
The large thing in upper left is dump pipe, the heat shied centre pic covers the CAS at the front on the bell housing, and about centre of that is the wire harness connector for it.
No need to disconnect wiring, but taking the plug form the holding bracket assists getting low for a bit of a look and clean.
Here 'tis . . .
So, mine had no particles on it, just a little dust, so gave it a good blast with CRC Sensor Cleaner, allowed to dry, and refitted . . . hmmm that sounded easy, let me rephrase.
I stuffed around trying to get 2 fingers on either side of the 10mm bolt head to do up by twitching the tips of my fingers so delicately so not to see bolt fall out of tiny space where it's located.
After getting the thread started, you can sort of twist a hand back at about 50 degrees and whilst scraping it on all sorts of brackets and protrusions, you can get the bolt up near finger tight, then about 15 mins to use short 1/4" drive fixed bar and socket to do up the last 1/4 turn.
There you go, easy. (HAH !!)
Ok refit connection in bracket, heat shield, sump bash plate.
I fitted a new (better ?) MAF sensor while doing this, the whole engine seems quieter and a little smoother, will see if the occasional sh!tty start is fixed, but I am suspicious it might be the crank angle sensor needs replacement, or glow plugs might need replacement.
Here 'tis . . .
