PK Ranger 4WD selection problem / resolution
Just wanted to post this up here in case anyone else experiences this issue in their PJ / PK, it might help get it sorted a little faster.
I reckon I can remember the first time the 4WD selection gave me an issue, it didn't want to go into or out of 4WD low range easily this time at Bendelby property in SA.
Anyhow, a little jiggling of things, sometimes going back a bit, the issue would sort out ok, and I just put it down to temperament of the system.
Gradually, things got worse, until one trip to QLD was up at Mt Mee doing a weekender with a brother, and after going up a nice little low range 4WD track that turned dead end, I returned to the main bitumen road to proceed further for main park access, and tried getting it back into 2H.
No way was it behaving, in fact it was pretty scary being so far from home.
It still showed 4L even after dong the transfer by the book from 4L to 4H stopped in neutral, nothing I tried enabled it to come out, pointing it uphill, downhill, forward, reverse a bit and try again.
Stopped vehicle and turned off in 4H hoping to reset the system, this has worked on numerous occasions.
Not this time.
You can have 4L light and 4WD symbol both showing on the dash lights, and it can be in 2H, and the speedo is all mucked up, showing lower speed you'd normally be doing in 4L, but you're doing at least double the speed.
That's a dead giveaway for this issue.
So I start asking around, and seems it's a fairly common thing, the 4WD Action forum (Ford PJ/PK Ranger specific) has numerous posts about this, and some of the things people have tried to fix it, mostly without success or not long term.
One such fix is on the transfer case (TC) 4WD module / actuator.
There's a little plate with T10 screws, and it looks adjustable, this is it . . .
This is actually on the back of the TC 4WD module, and tweaking it seems to have an effect, at least short term (so might get you out of a situation if it ever happens to you).
Alas the problems kept progressively getting worse, a Simpson Geo Centre trip passed by with a few hiccups but got through, luckily a second one in July too and Red Centre.
However, it was a lot worse, and let me down a couple of times when I REALLY needed to get in / out of 2H / 4H, but managed in 2WD to get past some soft stuff etc a couple of times.
So, I'd investigated this a bit more before going on that trip.
New module (my trade price) $1200, ONE second hand one at a wrecker in Tassie, $440.
A bit of a risk, as electrical parts not returnable !!
The wreckers did say that this part is a reasonably common failure, hence there was only one found anywhere !!
Oh, the auto and manual are different too.
Ok so Border Track a couple of weekends ago, it was a PITA to get from 2H to 4H this time, took 15 mins of BS'ing around . . . AND I woke up at Red Bluff and 4L lights are on, even though I left it in 4H when I pulled up.
Uh-oh.
Yep, was showing 4L but really in 2H.
Loads of backing / forwarding, stopping and turning off ignition, FINALLY the 4WD lights are out !! :)
Was going to go down the track a bit to the big dunes, but when the switch turned into 4H nothing, VERY unusual as it normally comes up 4H, and you know if this stays it is ok, OR the blasted 4L symbol comes on and you then know you're still 2H.
So, whatever it is it has shat itself.
At last.
So, order the second hand module, less than 24hrs it's at wreckers here form Tassie, and picked it up.
Fitted today, and IT ALL BEHAVES AS IT SHOULD :) :D
Still got to go field test the whole shebang this arvo, but 99.999% sure this is totally FIXED !!!
So this is it, and hopefully you never need one . . .
mac_man_luke
Good to see it finally fixed
Can the old module be opened up at all? might be able to see and maybe fix the point of failure? no doubt a switch or contact of some form.
Yes, really good piece of mind now for sure, all tested A1 again on a drive.
Have put the original one aside and plan to take a look one day, either a spare or maybe if it can be fixed just sell it ?
80lover96gxl
Glad to hear its fixed Les.
Sounds like its been playing up for sometime.
Hopping the new 2nd handy last mate and provides trouble free wheeling for ya from now on mate.
Ta mate, yeah was a bit reserved about going 2nd hand, how many kms it might have already under its belt etc.
But maybe the original in mine was a bit of a lemon, that's what I'm hoping anyway.
jacnden
I found this old post as I was searching for help with 4WD selection
The borgwarner transfer case on my Chinese car is almost identical to the Pk ranger that les has although it's a different model number and has what looks like an identical 4WD selection part
I have a mate with a pk ranger and we have looked at them side by side
So I've started to have similar problems , it usually engages ok but leaves light flashing on the dash when disengaged . I only have 1 light that say 4WD, no low range light . If I switch off the ignition this some times fixes it
I do have a spare t/case that's had little use ,with one of these on it , does anyone think it's worth swapping them over?
Or adjusting this part by turning a little each way?
Then every now and then I have issues selecting low range , always works eventually but it's a little concerning. I think this is the speed sensor on the t/case
You might find it helps adjusting it Dennis, many find it does help.
After a while if it still gives the problem intermittently, does you adjustment plate fit onto an actual 4WD module like in my pic above ?
As you can see, this is what my adjustment plate is part of, and replacing this module has fixed my problem permanently. For now.
It's a big pain in the patootie mate, all this electronic stuff, I love the old Paj setup in the gen one I have, a little stubby lever that is pretty much fail proof.
I'd say in the end you'll find your whole module will be shot.
Be interesting to get the Great Wall module price as compared to the Ford cost of ~ $1200 something + gst trade.
I went 2nd hand for $440, got one from Tassie wrecker, the auto ones are rare as hens teeth.
Freeride
Thanks for your informative write up Les , it seems I may be heading down the same path as you with my shift actuator.
I was over on Fraser last week and started having issues with the flashing 4wd hi light then 4wd low would light up when in Hi range.
Managed to make it work for the week but on the way home disengaged 4wd to stop at Eurong for lunch and when re-engaging 4wd for the trip over to Kingfisher had the lights issue all over again. After 20 minutes of mucking around selecting and deselecting I managed to get Lo 4wd so left it in low range for the trip over to catch the barge home. I tried loosening the Torx screws when home and rotating the plate but it had no effect unfortunately.
Annoying thing is my Ranger only has 40 thousand kays on it and that part shouldn't fail so soon but being a 2010 model well out of warranty.
I am apprehensive to put in a second hand one in due to the low kays of the vehicle so I guess I will have to bite the bullet and purchase a new one.
Is there anywhere on the PK model to positively check with fault codes as I believe the earlier models had a port to check the TCM but not the later models.
I will have a chat to my local transmission specialist about the Great Wall part and see what he suggests.
Cheers , Richo.
Bummer Richo, it really is a pain this issue.
My 2nd hand unit is performing great, but yeah it's a crap shoot fitting other than new.
Be good to find out if Great Wall might work, pricing might just be more reasonable.
Let us know how it works out for your particular problems.
Did you notice the erratic speedo issues also ?
Freeride
Yes Les , The speedo was erratic until it worked out what position the selector was in. Started up car yesterday with 4wd hi light flashing and tried everything to turn it off and thought I had succeeded when halfway from home to get a wheel alignment the car decided to go into 4hi on the bitumen with speedo reading about half of what I was doing.
Had heaps of trouble parking and getting the car onto aligner but when the mechanic gave it back it had gone back to 2wd.
It seems only ford can read the TCM fault codes here in The Bay so it goes to them on Tuesday to have a look. Service bloke said he knew all about the problem and would only need the car for an hour or so. Will be interesting to see what they come up with.
It's a bit annoying as the Ranger performed almost faultlessly over on Fraser apart from the selection issues.
Cheers , Richo.
You can pretty much bet it's that 4WD module for sure, the adjustment of that plate seems to help some, but when that fails, it's replacement time unfortunately.
Freeride
I believe the Dorman one doesn,t work on the Rangers as it has a different plug setup and doesn't select in the same positions.
Someone over on another forum found this out at his cost but he fitted one from a Kia Sorento and it is still going strong and selecting as it should.
If I can get some sort of warranty on the genuine ford one I may just go with it on mine but $1200 + is a lot of coin !
Richo.
muc the truck
Richo.
Have you checked to see if your ford part number is available in usa ? The reason I ask is I can buy SOME Colorado parts from usa a lot cheaper than holden .
