Piranha Dual Battery Management System
8UFF35T
ITEM:
It suits all 4wds
CONDITION:
Very close to say it is brand new,
REASON FOR SELLING:
Sold 4wd
PRICE AND PRICE CONDITIONS:
$250 ono
I can deliver the item but depends where you are.
EXTRA INFO:
It comes with everything, wires, brand new battery ternimal heads
Brisbane QLD
CONTACT:
PM
or 0433 449 389
PICTURES:
Discount Car Accessories :: Piranha Dual Battery Management System
It looks just like that.
MJB
ITEM:
It suits all 4wds
CONDITION:
REASON FOR SELLING:
Sold 4wd
$250 ono
EXTRA INFO:
Brisbane QLD
CONTACT:
PM
or 0433 449 389
PICTURES:
Is it the DBE180S+ unit ?
Big Rig
I just might be interested in that. Can you tell me at what voltage the unit closes circuit? Reason I ask is my charging system is very low voltage My last isolator wouldn't close the circuit until my charge rate reached 13.7 volts. I'm struggling to get 13.3 volts hence I ended up fitting a Ranox battery booster to my KK to keep the batteries charged while in transit.
8UFF35T
They say around 24volts, or 180AMPS +. That's why they named this system DBE180S+, so yes it should be able to handle your power output.
BUMP, just realised that this still has 3 years warranty... I had it for two years only, so yes it will come with the recipt.
Big Rig
Sorry my post probably wasn't written very well. The way a battery management isolator works it that it senses a run condition from your alternator. In other words it cuts the power to the auxiliary battery so that the cranking battery won't get discharged when the vehicle isn't running. There is generally a particular voltage the the management system must receive before it will close the circuit and allow charge to run to both batteries. I have a CRD Prado which has a very low charge rate so my concern IS will the unit you have actually open circuit at my low charge rate 13.2 volts. The closing and also the opening voltage is generally written on the actual unit itself. Could you have a look and see for me?
8UFF35T
Just looked at it and it said 12 volts, sorry man. I ran 2 x 12v batteries (main and aux),
BUMP
Big Rig
I'm guessing the 12 volts is just the indicator to a purchaser that it is for 12 volt units. The change over voltage will be in the vicinity of 13. something. This is the critical factor to me.
Big Rig
I'll try and do a little more net research cus its that kinda unit that would suit my application.
BEK
not sure bumping it every day will produce a sale.
Lowering the price may but it may be better to try other avenues of sale rather than just this forum
Just my thoughts
BEK
