DJs Timber
Ok, here is a pictorial on how to remove fascia to access the stereo.
To start, lever out each corner of lower climate control panel starting from the bottom corners.
And same as above for stereo surround. You can also disconnect the hazard light wiring as well by pushing on the tab on the plug to release.
Next stage is to remove the screw (circled in red) for each vent panel and then lever it off using your fingers. The screws in green are the ones you need to remove to pull the stereo out.
And for those that want to know how to remove the dash tray, you need to do all of the above to get at the two screws (circled in red) to remove it, once the screws are removed, lift the front edge till the rear edge comes free and then out.
