Patrol, fuel leak from vapour line out of carbon canister?
Outrage
Hi, been having a problem with petrol coming out of a line that just ends inside the chassis. Traced it back to the bottom of the carbon canister. This happens when I drive on either gas or petrol. Vehicle is a 2000 Gu Nissan patrol, the TB45 engine.
Taken it into a mechanics (my usual one, he's good) and he can't find a definite source of the problem. Replaced the fuel pressure regulator as that fixed a similar problem with another patrol he dealt with. The problem did stop, been a couple months and it just started back up again, took it back and he can't find anything still, regulator is functioning normally.
Did say the carbon canister is twice as heavy as it should be as it was completely loaded with petrol, cleaned as best he can, stated it could have been (a guess) fuel still in there prior to replacing the old regulator that finally came out from a build up of pressure. Now said to just wait and see if it does it again to see if that was the case or if something else is wrong.
He did state earlier on that he thinks the line where the fuel is coming out is actually meant to go to the fuel tank, however whoever done the install of the long range fuel tank hasn't moved that line/done it properly. But either way also stated that liquid fuel should not be coming out there as it's meant to be a vapour line. Was a while ago, so can't remember if this is really what he said.
Got some pics showing the setup and where I have spotted the leak.
Any suggestions to what could be wrong?
Carbon Canister - Fuel tank hose i believe goes to proper location, can't trace it but goes to correct side of car for fuel tank.
New pressure regulator - hose directions to carbon canister
Additional picture of this, showing section of line hidden by intake manifold.
End of line where petrol comes out - left hand side chassis rail, located mid length of the car - you can see evidence of fuel leaks. Line actually sits inside chassis, just pulled out for picture.
Trace to bottom of carbon canister - showing where this hose connects to carbon canister with a T section, right hand section of T I don't know where it goes to but fuel leaks from it too.
Unknown hose from right side of T section, just showing the leak.
croozza
Looks like you will have to run the fuel down to empty and have a diagram of the correct hose and breather locations for your vehicle, then remove the tank and see if you can match them up, like your mechanic said, fuel should not be going into the canister nor should it be coming out of a hose in the chassis rail.
monk2
had a 60 series with a simular problem petrol coming out of the rep carbon canister and also been converted to gas and had a modified fuel tank fitted but it turned out to be a faulty one way valve in the rear quarter panel on the right hand side of the car plus the tank was pressurising fuel cap a bit suspect as well replaced the valve assemble and fuel cap had no more problem, not to sure about you GU and if it the same but check to see if the fuel tank is pressureising as this will push the fuel out of the easyest exit
Outrage
Looking like there is a breathing issue, it's in on Thursday to get it checked/fixed by the mechanic.
Matt
jack48
Next you will tell me thats why you didn't make it up Stringybark Tk, LOL, I know that was the reason so no more excuses, it just sounded like you backed off near the top.
You'll have to have some revenge on that track when its fixed,
Outrage
Was actually the little plug for the air flow sensor popping out, it's never done that before. Going to tape it down tight for that revenge :). Doesn't look broken, think it's just worked it's way loose over time after quite a few bumpy rides and that hill was the last straw.
Outrage
Yeah, took it into Matt at GOR. Diagnosed the beginnings of the problem on the first day he had it. Petrol tank (being on gas it is now the 'main' tank) had the old 'sub' tank fuel pump in it still, they are different, sub tank pump does not have a return, so whoever installed the gas/long range tank system (was done before I owned the car) instead of switching the pumps they fed the 'return' line into the 'breather' outlet of the tank.
So the petrol system could not breath so it was finding the next easiest path when the pressure built up and that was through the emissions system/carbon canister and then dumping petrol onto the ground.
Along with going into my auto elecs and their mechanics at Peerless Auto to get the gauges working and the gas wiring was also a mess. They fixed all that up.
Altogether was a dodgy install, twice as much hosing as needed, crimped off tee's instead of smooth 90 deg bends in places, etc.
All fixed now though :). Comments from both GOR and Peerless Auto, it was such a mess of an install, in the end it was practically taken back to scratch to start again. With Matt's work I ended up getting another 20L of usable fuel out of petrol, and consumption dropped from around 30L/100km to 20L/100km (that 10L probably ended up on the ground), shows how much the bad install affected the system.
