Patrol Engine Upgrade
Big Matt
Ok guys, the decision has been made, im going to replace the TB42 Ozone destroyer in my GQ with a Holden V8.
Reasons ?
1> At this point im lucky to get 30 liters per 100 on Petrol which is just sh*ting me. I know a guy who knows a guy (yeah yeah i know how it sounds LOL) who used to have a 5ltr Patrol, and he used to average out 15 to 16 ltrs per hundred on 33's with his. I know the person in question, and he isnt prone to BSing. Yeah the fuel consumption went up to 20 - 25 when up the bush, but at steady speeds on the open road (1400rpm at 100k) it wasnt bad.
2> The V8 will be easier to keep dual fuel on than a turbo RB25/30, simple as that
3> The Holden V8 is a strong motor, has an oversized block and iron heads (which is my preference) I also have owned a bunch of them so i know my way around them (as does EVERY mechanic in the country) which will be a benifit
4> Its a cheap engine swap compared to a lot of the other options i have considered
So if anyone has had experiance with a similar conversion id be greatful for any input or ideas on elecs such as ignition water proofing etc (the loom wont be an issue as the person mentioned above who had a similar truck is an auto elec and has offered to wire her up), cooling or anything else that comes to mind
jack48
Hey Matt check out Ebay and you will proably find a truck already converted to V8 and either swap engines etc or use the new truck. Cost of adaptors etc is huge, found this out before I purchased the Tonkadore, adaptors etc for the V6 conversion alone was about $10,000 plus engine, have a good look around first
Big Matt
Owning CNC machines and 20K worth of CAD software (and knowing how to use them) i wont be paying for adapters ill be making them. From what i have seen the adapters are a rip off and for the most part they dont fit anyway. I know someone who used adapters from someone who will remain un named, and they were useless.
Also a mate who is a mechanic is going to give me a hand. Having looked at a few we recon we will get the engine and all the main parts in in a weekend fairly easily. Then its all the small stuff
Big Rig
Have you spoken to Brunswick Diesel in WA. They will do you a beaut Chev V8 Diesel conversion. PM Frosty or Splitpin or even Towie.
patsBIGMAV
Hey im just wondering but have you thought of TURBO mod? A lot of blokes done this and they said it was well worth it. also cheaper than swap conversion. As for fuel issue it made a difference as well. A guy did his conversion running 0n 10psi with 197KW on 33's. took his patrol on highway and with less than 1/4 of juice got him to 140K so with a full tank you will get at least 450-500 or more depending on how you drive it. His vehicle is running on STRAIGHT GAS by the way. Check out patrol4x4.com outerlimits4x4 mudrhino.com.au they have some helpful stuff. Im going to do this as soon the money comes up. Goodluck.
Regards,
Pat
Big Matt
Cheers for the input Pat
I had thought about boosting the TB42, but i didn't realize that there was much of a gain in economy to be had.
My main reason for going a V8 (looking at a RB 25 now) is i want to run straight Petrol and dump the gas all together. I have talked with 2 guys who have done the RB25 conversion in GU's and they are getting 15ltr's per 100 and have a stack more grunt than a TB42
As a side not, the RB25 NEO has more power and torque than a TB48, with peak torque coming in a few hundred revs above the 48's, so that could also be a good thing
Other upside of the RB is its basically a bolt in fit to a GQ using the RB30 parts
frosty
Just to confuse you a little more. Just worked out my fuel economy properly. 13Lt's / 100km's. Around town and towing. On the highway fully loaded, (roofrack, trailer, about 4 tonnes +) I got 15.8 average. Makes 470 NM @ 1700 RPM.
croozza
Anyone no how much work to change a 4.2 petrol engine to a td 42
There is a bit of work to do to change from a TB42 to a TD42, firstly you need to wash out the fuel tank,, and change all the fuel lines, as the TD has larger lines, you will need to change the sender unit and the instument cluster just to name a few.
Croozer
Hey Matt why not go for an early small block Chev instead of the holden? Performance parts are cheaper stronger than the holden, narower V, 4 bolt main etc etc. Quite a few positives to run a bowtie instead of a lion...
Big Matt
If I could get it to run 17ltrs per 100 I'd consider it
The holden V8 has been put aside in favor of an RB25DET due to the inherent reliability and economy of the engine. Also due to the fact that it will bolt straight into the bay using the early RB30ET mounts hoses etc
@ Frosty I'd love to go a chev diesel V8 but the conversion would be worth twice what the GQ is
If I had a GU I'd do ot in a heart beat
Croozer
You could probly get your 17ltrs per 100 alot easier with a chev than running holden motor.
PSI 80
Now your talking Big Matt........... TURBO. You will love the grunt. I've got 641 nm at the tyres (35"), with plenty more to come, and thats only at a nice safe 7 psi boost. More tune work to come yet but so far we manage 20 odd litres/100km.
hey matt when you knock up your conversion bell housing kit throw one my way im about to convert they same as your thinking??????i will buy one of ya for 308 conversion the prices out there are poison????
rickgq
I did a 308 conversion for a mate of mine, If doing so consider replacing the cam as the stock setup doesn't run the best when your rock crawling at super low rpm
