Panhard bar from crapdog (warning)
Nkelly
Bought a toughdog adjustable panhard bar from 4wd1 in september..
Broke on me in pakenham last week,lucky i was only doing 30 kph around a round-a-bout not 100kph 20 mimutes prior on the woori yallock/pakenham road,so i contact 4WD1,they tell me that they dont warant the panhard for my application,their panhard rods are ONLY designed for leaf spring vehicle's ??
But on 4WD1's site and toughdogs site it says : too suit any application no matter the suspension system or lift..:rolleyes:
Did a copy of the web page before the wording suddenly changes for some strange reason.
Took it too a engineering shop,and they were horrified how the peice of tube that is welded too the bush is ONLY pressed onto the thread of the bar,not even welded.
They suggested i take it too vic roads..
So be careful guys if you got 1 of these panhard rods and you are running coils on the front,because it will take off like it did to me,get underneath and have alook and if its creaking dont drive the vehicle,because thats the sound i heard before it let go.
BUSHNUT
Gee ! Just looking at the end of that shaft - that has been in fatigue for some time ! you were luck !
Pure Yobbo
Just remember there would have been a clauseon the invoice something along the lines of For Offroad Use Only. Vic roads won't really be interested.
Give them a call maybe it was a fault in the batch.
I stripped the inner thread where they adjust on a tough dog front panard on my GQ but I put that down to wear and tear it gets driven pretty hard. I also think the panard may have been a medium duty one as it didn't weigh a great deal.
I now run Superior panards.
Vegetoast
about 2 year ago the eye ripped open on mine, same thing, about 30k on a roundabout. it was a strange feeling when it happened.
Nkelly
Have you tried ringing Toughdog direct to see what they say!
Yer they told me too ring 4WD1,and 4WD1 emailed me back saying: toughdog dont warant their panhard for my application,but what they say now and what it says on their add for the panhard bar is 2 different things,their just excepting no liability AT ALL.
Nkelly
Well 4WD1 never mentioned anything about off road use,and i reckon vic roads will be interested because people are buying these things for onroad use,because the add does not say anything about off road use only.
4WD1.com - Ford F250 Shock Absorbers, Suspension & Accessories
I'll find the paper work that come with the bar,but i dont remember seeing any conditions of use..
cptmud
was looking at the link you sent, they say coil sprung 4wd, then mention any suspension type
Panhard Rods - Tough Dog Adjustable
When a raised-height suspension system is applied to some coil-sprung 4WD vehicles, the fixed length of the front or rear panhard rods can cause the axle to shift to one side. This is most obvious when one wheel protrudes out past the vehicle's guard (fender).
TOUGH DOG heavy-duty adjustable panhard rods eliminate this problem. Enabling you, whatever your suspension type or lift height, to set the rod to the most appropriate position. Free Australia-wide delivery.
might even have to go to consumer affairs or even threaten them with 1 of the current affairs programs
sometimes this is enough to get a result from them
Big Matt
Yeah do that, id call Tough Dog again and explain your situation as well, and tell them, sort it out or im going to consumer affairs etc
The other seemingly popular thing to do with dodgy suppliers is bag them on outers LOL
croozza
Ummm, leaf sprung vehicles don't use panhard rods, as the diff is centralised by the leaf springs, unlike coil sprung vehicles where the panhard centralises the diff/axle. I would take it up with fair trading If I were you.
Just another reason NOT to use shonky dog!
Nkelly
Its not the money that annoys me,its their "we dont give a shit attitude",so i am going to take it it up with consumer affairs..
Thanks fella's
Gator3535
Vic roads will not give a sh$$ .. they are only interested in it if you can prove fault and then they may back you in court .. but they have NO interest in helping you directly.
I quick call to them will show what I mean.
Nkelly
Thats sad if true,why bother with all these roadworthy blitz's their having then,i reckon this panhard bar is pretty unroadworthy.
If they dont give a shit i'll tke it to a vehicle engineer that tim @ rocket sports trucks uses too pass his Ftruck modifications.
Vegetoast
What did they tell you:bad luck because you have'nt got leaf springs...
I never chased it up. Just thought how lucky I was it never happened at high speed and replaced it. With what I make my truck do you have to expect things to break, atleast that was a cheap repair.
Nkelly
Well if i had been doing something crazy,maybe i would except it,but the truck has been on the black top all the time havent been off road once,but even saying that the panhard bar should be made too handle offroad conditions at all times other wise state "on road use only" when advertising your product...
Its just CRAPDOG ... junk even me so called heavy duty steering stabiliser self centering isnt that flash,might pull that off and chuck it in the bin and try something else..
croozza
Obviously a lesson here for all, something I have been trying to put across for ages, avoid crapdog/ruffdog.
Jarh73
Two words instead of tough dog: Superior Engineering.
I replaced my tie rod with Superior one (the solid one) and the way it's made and finished off is first class.
Problem with a lot of aftermarket products is that a lot of the stuff maybe designed here but often built overseas and there is not enough quality control when items arrive to determine if it's actually been made correctly and the right materials.
Justin
