Pajero wheels.
canyonaro MK1
Wondering if anyone could tell me, just off the top of their heads, will 15" rims fit on a '98 pajero?
Our new (well, new to us anyway) '98 pajero has 16 inch rims. My '95 super paj has 15's and i have set my camper trailer up with 15's so all wheels and tires are interchangeable.
I know what your thinking, just go outside and take a wheel off, but i'm thinking more about legality regarding minimum required clearance from calliper's etc.
Also, the '98 has all terrain's for the mum's taxi duties it's usually doing, but it would be nice to know that i can swap the duratracs off the super paj for a wkend away.
SnowBoarder
Hi Canyonaro,
From the info I have, 15" wheels were an option on Pajero's up until '98.
First thing I would check is the tyre placard, normally located on the inside of the drivers door jam. If there isn't a 15" option listed on that, regardless of whether it bolts on or not, it would actually be an illegal fitment - while it may fit, your car would technically be unroadworthy. This bothers some people due to insurance reasons etc, some people couldn't care less and just go with it anyway.
In terms of brake caliper clearance, my opinion is an inch is as good as a mile. And last time I checked, as long as there was clearence, it was legal. If there is no rubbing or fouling of the caliper in a static situation, you should be fine while driving. If you then end up in a situation where the wheel rubs the caliper due to damage, I'm tipping that the wheel rubbing will be the least of your problems....
Finally, the difference in wheel offset from the factory 15's (factory offset of +33) to the factory 16's (factory offset of +10) appears to be in the vicinity of 20mm, meaning that the 15" wheels would sit 20mm further in than the 16" wheels. Again, quite illegal and potentially dangerous (as well as having absolutely no advantage to handling or off road performance). Steel wheels (sunraysia style) are available in 15" with the +10 offset so you can maintain the factory fit while dropping down in rim size.
prawns
My 93 GLS pajero was released standard with 16's and plastic flares to make them legal
The 93 GLX came standard with 15''s and no plastic flares (they wernt needed for this size wheel as they are flush with the metal bodywork)
In my GLS model at least you can legally run either size wheel as they were released from factory with both sizes fitted (infact when I bought mine it already had 15's on it so Im stuck with them at the moment, and yep they do recess in about a inch more than the plastic flares stick out - kinda looks wierd and if its annoying I guess you could just remove the plastic flares and have the same body and tyres as the GLX came out with standard - GLX your GLS lol)
If you go the other way and have a GLX model pajero with 15inch rims and want to install the factory GLS 16inch rims - you would also have to install the GLS plastic flares so the tyres dont protrude past the bodywork.
Check your tyre placard as mentioned I reckon - it should answer your question about whether the 15's are also a option or not for you in your newer pajero (not sure on the newer ones and somebody said there was changes in 98 so...)
PS Ive seen cars with only around a 5mm gap between the caliper and the rim itself - As long as there is some kind of gap and its not actually scraping I dont think its not a issue personally :)
canyonaro MK1
Thanks everyone. Seems some people did know this stuff "Just off the top of their heads!":rolleyes: Think i might stick too towing the camper with and goin bush in the old '95 Superpaj, and leave the '98 for driving the kids to school.:eek: (Which, incidentally, requires a 4x4 on occasion from our place!):D...............The new one is just so much nicer?;)
