pajero oil presure........dodgy
spice1
Not sure what going on......
In the morning when i start my nj 3.0 v6 paj up the oil presure rises and returns to normal while idling.
But as soon as the the car gets warm it shows nothing on the oli presure gauge at idle. when i rev it the presure comes up to normal again.
when it idles i can hear a knocking or ticking sound down low like near gear box or just infront,(not normal tappet noise when low or no oil) but again soon as i rev or hold on 2000rpm all is well. been like this for a while
Any ideas?,,,,,,,,,,,,,, thanks.
Qute
You don't wanna know...
Could be a big-end or Main bearing on it's way out which is allowing pressurised oil to leak out of the crank instead of going where it should.
Could be a badly leaking rear main losing your oil pressure.
Also could be worn main/big-end bearings or just an overall worn motor.
Also could be that you are using too thin a grade of oil.
What's the overall condition of the motor? How many K's?
spice1
yeah done a few k's 260,000. but the motor seems really strong and doesnt use much oil at all between services. would an oil pump cause this problem, although why would the presure come up under revs. the big end bearing thing seems to make sence. but why would it be fine when cold(ah cold oil right,.... when warm getting through somewhere), but would i not notice lose of oil.
lots to think about thanks.....
Qute
Easy first diagnostic step... Change oil and put some slightly thicker oil in it...
Yeah, could be a worn oil pump...hadn't thought of that one.
crackers111taz
I wouldn't panic spice, more than likely (in fact almost positevly), will just be a bit of a dodgy oil pressure switch. If the car is running fine, not using oil and giving you no trouble, then don't panic. If you want to eliminate the possibility. then pop down to Bursons,Autobarn, Supercheap etc etc, and get yourself a new oil sender unit (around $50 I believe) and that will most likely clear up the problem. Very common for the oil pressure units to not read accurately in a Pajero.
[/I]
Mud lark
Mine did the same mate when i first bought it.Use penrite oil now and the oil pressure is better at idle.
Big end bearings is my problem!!
