Hi guys! It’s a pleasure to discuss some stuff with u.. I own a mitshubishi montero year 2000 2.8 manual and I’m stacked with its 4wd failure.. It shows error codes 33 and 41 when I checked it manually. The previous owner said he replaced clutch plates and then the 4wd did not work and the 4wd system has not worked for nearly 2 years. I Removed shift actuator boot and cleaned it with WD40 and greased well but still the problem is there.. I know u guys can help me in this matter as u are well experienced in these matters.. Thank u !
