Pajero lifter noise
NLPAJ
Does any one have any info about the 3.5 v6 sohc pajero NL lifters? are they adjustabe? mine make a intermittent ticking, not all the time and not very loud as if its only 1 or 2 doin it. should i just stick some 'lifter free' in it or is that a bad idea?:confused:
cptmud
welcome to the joys of owning a pajero, need to look at mine as well, so ill be watching this thread
shovelboy
No they are not adjustable and what i would do is give it a oil drain and add the genuine Mitsubishi oil and let it run that for a while and see how you go cos if its only a slight tapping noise this oil will usually fix this problem
Webguy
Do your tappet covers leak like sieves as well? I had mine replaced a while back, and the bolts that hold em on are always loosening off and leaking oil.
NLPAJ
My rocker covers do leak a tiny bit but I tightened them up not long after I got it & haven't degreased it to see if it still leaks or it's the old oil still on it. The oil is only 6000k old & I change it every 10 even though the handbook says 15. Not to concerened about it might just put a bottle of Nulon lifter free in it & some engine flush before next oil change.
