Pagero Lift help
Grumpy
I know someone out there will be able to help me to find out what is required to lift a 1998 gls Pajero and also what it involves. Cheers
Ekki Adventurers
Hey Grumpy, Wooky says you can lift the back end as high as you like but the Pajero's are limited on how high you can go in the front. Is it leaf or Coil rear end?
shovelboy
Hey grumpy go to bursons they sell Ironman lift kits for the Pajero and are easy to lift and are a reasonable price too ..... As you know i have a Pajero and have it lifted 2inches from standard
If you want to raise the rear just need standard height rear GQ or GU springs which fit the Pajero and then just wind up the torsion bars
cptmud
yes, but winding up the torsion bar, reduces articulation, and cv angles are messed up
BUSHNUT
Hey Oh Grumpy one , I have got a full set of GU ute springs ( standard ) that you can have .
Standard shocks too if they are any good to you .
smitty
that sounds good thanks bushnut catch you at O'tooles.
thanks everyone gives me lots to think about
shovelboy
GU ute springs will make it too high as they are alot stronger for extra strength and load carrying and as for not being able to wind up torsion bars thats all your doing with the new ones when you buy them but they are heavier duty. So all Pajero's out there have had there torsion bars wound up but to get more articulation you need to get someone that knows how and how far to cut the bump stops down to give more articulation
Grey Ghost
That last bit was the bit I've always been wondering about too, thanks for that, I can do that to the Triton too :D Would you also maybe loose the anti sway bar as well to help with the articulation?
shovelboy
yes you can lose the sway bar but that will increase your body roll though so might be better to source out a longer link for the outer part of the sway bar
