OziExplorer Tutorials
goanywhere
Thanks mate. Opens up some of the features I was a bit unsure about making use of until now. OziExplorer is really a powerful tool that I haven't been making the most of.
matt82
Me too... If anyone knows how to setup a rooftop map on ozi explorer that would be extremely handy im quite new to the maps side of thing and having trouble with the right settings for my map.
cheers Matt
mauriceb
What device do you have Matt as Its simply copying the rooftop map folder to your existing map folder . Map folder could be in default internal memory or sd card on Android or Wince devices. If your referring to Ozi pc. map folder is in C drive /Oziexlporer /Maps. New maps then need to be reindexed. If this is your first initial install all configuration paths need to be set and correct .
matt82
I purchased the rooftop paper map and scanned it now im struggling to configure it as i cannot see zone 55H in the list and i do not know what format i need to enter the gps coords in to set the points on the map.
i scanned the map to pdf then converted in to PNG but as i dont know how to do the config i cant make the .map file
here is the info i am using from the map
mauriceb
There's a lot of instructions involved to explain how to calibrating the maps so i will post a link . I converted all my Rooftops sheets to .ozf4 . i had office work scan them to .tif your can also use pdf . It takes a bit of practice then you should check if its correct. this may help.
New link required:
