Oziexplorer calibration into Hema5i
Murph67
G'day, I am from Perth and trying to get 25K maps for the Perth area onto my Hema5i. The Greg Harewood CD's are $70 a pop and 40 years old so am keen to get something a bit more up to date. I had a few papers maps (circa 2008) so have calibrated them in oziexplorer. There are no problems reading them in oziexplorer on my PC but when I load them onto the Hema is does not recognise the map file. I have searched for an answer but come up with zip. Would welcome any suggestions and known solutions.
banshee
how did you calibrate the paper maps to ozi??? I have a heap of paper maps and have always wondered about that before they get too manky..
Firstly you have to scan them in. Often they are larger than a home scanner so you have to get it done professionally and that has 2 problems. 1)It costs $10 - 15 per sheet and 2)if your maps are not brand new they will have distortions from folds etc.
Then you can calibrate the picture in Oziexplorer you can use the grid lines as references and "tell the map" where these are electronically. You need to do at least 2 opposite corners and preferably more point.
It will probably be easier and cheaper to buy electronic maps unless yours are special or not available electronically.
Murph67
Banshee, check your dates and scales on your hard copy maps. I found that I could not get 25K electronic maps less than 40 years old for the areas I was interested in. My only recourse therefore was to buy the latest hardcopy maps (about $10/ea), scan and calibrate them.
A couple of traps for young players were however that the cut down version of Ozi that came with my Hema5i does not allow you to calibrate scanned maps so I had to buy a full version of Ozi ($130). I then found that I had to run the utility suggested by Booboook and convert the file to Ozxf3 format to get the files to load and run on the Hema.
If you are going to calibrate your maps I suggest having at look at the following TouTube site:
Calibrating Maps for OziExplorer - YouTube
Good luck.
banshee
Thanks fellas...check out this website - gov one for maps would this doo for ozi you reckon..
http://mapconnect.ga.gov.au/MapConnect/
it is only 250k but you can zoom in and get the maps closer to any area you want for free they send them to your email...always wondered if you could calibrate onto Ozi..
Oh i have the full version of ozi and 25k maps for cape york all the way to back of cairns/innisfail areas and they have most of the roads/tracks/wheel ruts we have found and quite a few that where not there too...
banshee
I might have access to some "special" maps that i might want to put on my GPS...lol:p
Thanks for the info..
