OX Hydraulic winch
ROCK64
I'm keen to fit the OX hydraulic winch to my 2000 HiLux.
In addition to hooking it up to the Power Steering Pump, I will add an oil cooler into the system, mostly to give more volume to the power steering fluid.
Any thoughts, comments, experience or advise please!
Rock.
justaguy
I have heard the OX is a rebage of the Mile marker in the US.... Check them out they have some great videos and they have the contract now to replace all the winches for US defence....
I believe Snake racing import the electric ones in Australia they may be able to get the Hyd ones
See ya
winch
Friend of mine has 1 on a work vehicle said there good strong pull had no problems but next time going electric only because if the motors not running no winching happening
Booga38
Ox hydraulic are infact Mile maker out of the states, they are excelent winches, i have an eletric but wish i still had my old ox hydraulic (had it in a earlier cruiser that was writen off by flood), it had more control, stoped when you needed it to with out the electric over run. It ran all day, same speed all day.
Yes if the engine is not running nor is the winch, but neither is electric when it runs flat your batteries, (if you have two), there is next to no battery draw on the electric system with hydraulics and because it is running through your power steer hydraulic system you know it is ready for work all the time, unless your steering is not working, unlike a electric that can become electricaly siezed or faulty from water ingress, and the first you know is when you pull the trigger and zero happens. They work under water also.
I had both the extra cooler fitted, which is just a trans cooler. I also had the bypass switch and valve fitted, it allows the steering to be bypassed and all hydraulic power when to the winch only, if i needed to move the steering wheel, i just flicked the switch back on and turned the wheel, the winch just slowed slightly.
I know some cars like early fords and mazdas did not have the same oil flow or opperating pressure that a Toyota does and therefore they opperated slower when fitted with one.
Yep still wish i had the old winch!!!
