Owners manual 2004 Hilux
Yooper
As the title states, I'd like to find an owners manual for a 2004 Toyota Hilux.
An alternative would be a copy of the pages showing what dashboard gauges and idiot lights should be there. I'm thinking I've got a couple burned out bulbs behind the instrument cluster (for the idiot lights), but I'd like to verify before I tear the car apart.
typhoeus
pulling the instrument cluster is not a big job. . maybe 30 -40 minutes. The idiot lights are very small bulbs. with wire pins at one end that fit into a plastic holder I think I paid about $1 each for them so I bought 10 and fitted them to every holder, even holders which aren't even connected to anything in my model, that way I got spares there when I need them next time
Pork Hunt
I had an 04 xtra cab. It had power windows and air from factory but most of the lights in the dash wouldn't light up. Temp and fuel gauge worked and the alt light is all you need. Belts on and door open lights are a pain, especially if there is a bell to you remind you.
Is there a glow plug light, a brights (high beam) indicator, or a 4wd indicator?
Yep ,Yep and Yep..
Glow plug is orange on the left side of the instrument panel,, stays on for a few seconds. High Bean is Blue, and the 4wd is green on the right side, if you would like to talk to me about it, just pm me with your mobile and the best time to call you, I also have Toyota manual with diagrams etc.. You can buy of the net for 12 bucks also
Yooper
Well, pulled dash. High beam light & 4wd light burned out; apparently it's hot enough out that the glow plug light kind of blinks for a second when you initially turn the key and if you're not looking for it you'll miss it.
4wd indicator still not working, guess I have to start tracing wires. Still would like an owners manual if anyone has one they don't need.
Well, pulled dash. High beam light & 4wd light burned out; apparently it's hot enough out that the glow plug light kind of blinks for a second when you initially turn the key and if you're not looking for it you'll miss it..
Glow light should be on for about 3 seconds plus
03hilux
I think I still have the owners manual for my 03 Hilux. It should be the same for an 04 model.
Im not sure if the manual shows dash light replacement though. That might be a job for a gregorys workshop manual.
