Over night awing
RussF
Hi All,
I am seeking ideas from others for a quick awing to attach to my canopy roof racks and cover about 2 sq mtr out the back of my ute
I do a lot of 1 nighters in the and at the moment I use a silver tarp and a couple of exterbale poles pics would be good
Cheers Russ
dno67
The simplest way would be add a length of sail track to your canopy via rivets or screws and heave a
trap or a canvas awning made too suit, needs a rope sewn in on the edge so it can be attached to the sail track. Easy to role or fold up to store and only on the canopy when needed.
Bomber2012
I'd stick with the silver tarp , if it's quick to put up and does the job why change ?
You can buy rear awnings but they are fixed to your truck (unless you can devise a way of taking it on and off quickly).
I have a 2m x2.5m side awning on mine that's 2 yr old and have had no problems with it , it was $130 roughly ??? and if it bites the dust I'll probably replace it with another cheapie from the supacentre.
I reckon that is the go too.
An alternative to having one made up is to buy an awning side, costs about $100 and it has the sail track edge already on it and eyelet holes on the bottom , you just need to fit a sail track then
An alternative to having one made up is to buy an aaning side, costs about $100 and it has the sail track edge already on it and eyelet holes on the bottom , you just need to fit a sail track then
Edit: this sort of thing
http://pages.ebay.com/link/?nav=item.view&alt=web&id=331302561438&globalID=EBAY-AU
For what they're worth, I would just go a commercial awning of suitable width.
They are all self contained, are up in a couple of minutes, and just so simple / easy to use.
Here's a couple of rear awning examples . . .
Ummm, jeez, I take that back (the 'for what they're worth' part), all awning sizes appear to have gone up significantly in price of late !!!!
Tigerz11 1.4 x 2.0
Gordigear 1.4 x 2.0
Have you seen these ones below ?
Anaconda Quickstop awning
Anaconda Deluxe RV Shade
BCF Wanderer Instant RV Shade
sharkcaver
I made my own rear awning, sail track mounted to a roof bar. Easy to set up, but it really needs spreader bars to stop sagging in the middle. Seeing you are then going to all that trouble (IE 4 poles) its probably just easier with a cheap roll out one. If the silver tarp works, stick with it. KISS. I really, really like the foxwing too. Except its cost, weight and ease of set up. But once under one, its brilliant.
RussF
I have The tarp the set up down pat a few minutes and were good just flaps around a lot in the wind
Cheers for your reply
