I am using Nulon semi-synthetic 20/50 High Kilometer Oil at the moment with my 320,000km 2.8l patyrol motor. It seems to hold its viscosity very well for the 5000km between changes. Probably used it for about 6 or 8 changes so far. Bit expensive at about $40 for 5 litres. But I grab a few when it is on special at SuperCheap at $30.
If you are doing a lot of short trips where the motor does not get a decent run at proper operating temperatures, then the condensation that occurs in a cold motor never gets evaporated out of the oil.
This moisture causes the sludge that can block your oil control rings, and other things like your oil filter I guess. Then when the oil rings get sludged up it can bake hard and then you have no oil control, and the motor will start burning oil. I was using the 40/70 oil for a couple of years, in my old Patrol motor, trying to control oil burn. It helped a bit, but then it just got worse and worse. It got to the stage where it was burning 1 litre of oil every 300km because of sludged up, 'baked hard' oil rings. So I pulled it apart and gave it some new pistons, rings and bearings.
My wife's lovely VT Commodore has only 130,000km on the clock. But she does only about 5000km a year. And most trips under 2km!. It sounds like you are doing lots of short trips too. I do three things to try to prevent sludge build up in her car -
1 - I change her oil at 6 month intervals, even though she has only done about 2.500km. I figure that the oil would have soaked up plenty of condensation with all that cold running by then. Time to get rid of it and treat it to some new stuff.
2 - I take her car instead of mine, every now and then, when I know I am doing a 50km or maybe 100k or more. A bit of a run where the oil gets a chance to heat up and so hopefully let a bit of that moisture steam off.
3 - I add half a bottle of de-sludger additive and go for a 10km drive or there abouts, to both warm the oil before dropping it out, and to try to loosen up the sludge that can start collecting in all sorts of places in a cold running motor.
A good mate asked me to come over and have a look at his motor that was sludged up. It was awful. Like thick black plasticine, all through his rocker cover, and under the side plates. We had to scrape it off with a knife and spoon! He was using an oil that had a reputation for causing this I think - Castrol GTX. But this was 20 years ago. Apparently I have heard they have done something about it. But I also think he was just very slack in changing his oil! He was not doing it often enough! And was probably doing lots of short trips!
For maybe 500,000km or more I have used the good old Valvoline XLD oil 20/50 in my Holden 6 cylinder motors. Never had any sludge build up with it. But I do lots of longer drives, and religiously change the oil every 5000km.
Maybe just do a few quick oil changes to try to clean out any sludge, and use a half bottle of de-sludger just before each change (instructions on the side of the bottle). When I say quick, maybe just leave it in for 2000km. Maybe even just 1000km. Just use a cheap oil for these. No need to spend more than $25 or $30 for 5 litres. Maybe that will clean out all that black stuff you are talking about. And then try those three tips above to keep that sludge under control.
