oil leak
Nick Clissold
Nissan navara 2011, automatic.
Been 4x4, have hit the bottom of my car very hard in massive mud puddle and water, and have a major oil leak from above the sump, and I am not sure where it has come from.
I have lost majority of throttle response won't rev past 2rpm.
Any ideas on what's happened to my car? All transmission works fine.
Please help !!!
muzza22au
Take it to a mechanic or get a mechanic to come around and have a look, it doesn't sound good at all.
typhoeus
your not having much luck are you? Hilux with electrical issues & Nissan with sum problems!! I reckon you shold avoid those mud puddles!! :eek: clean the engine with spray on degreaser and hava look, you might have split the sump or even the oil filter. check the dipstick, make sure there isn't water in the sump. That would push oil up maybe into the rocker cover where it could get sucked into the intake.
Nick Clissold
It's all clear? Which is odd, we're going to take it to Te mechanic and see what they think! Cheers mate !
