G'day Fellas, about to do an oil change on the 200 and I think I'm going to need a special oil filter wrench as this is the cartridge type filter.
My question is do I need to buy genuine or is someone doing a generic type of spanner.
Cheers for the advice in advance,![]()
Hi I bought one of ebay I think they are also available at supercheap. Basically I its a 64mm 14 flat socket. It comes with an oil bleeder which I rarely use cause its more trouble than its worth. You need to remove two guards to access it and then its pretty straight forward. Regular oil changes are the cheapest insurance you can buy![]()
Which guards are you removing to do this? I f it is straight forward may start to do this myself, been getting Toyota to do it
cheers
Well I ended up buying a genuine filter wrench from Toyota it was only $30. Bargain.
Changed the oil was a bit time consuming with the cartridge filter but the next time will be quicker..At least the job was done to my satisfaction![]()
