Off Road Trailer.
Towie
Ok Party Goers here is a few pictures of the off road trailer or anyone looking into doing one.
this is my first design for an off road trailer so any ideas or tips will be much appreciated this guy builds them tough & i have given him a bigish list of custom ideas.
This will be going up & down Cape York so its very heavy duty.
Having it setup as a tilt trailer but we are using a jockey wheel mounted to wind it up/down to control how much tilt there is.
Spare tire mounted under the Bow but i have it setup so i can mount it on the drawbar to make it a 3 wheel trailer so i can winch or pull it when neccesary. A jockey wheel will break in these conditions & is of course too small.
Standard removable jockey wheel & it mounts flat on the draw bar when not in use.
33 inch tires on patrol rims same as the ute.
Independant suspension with shockies.
Hydrolic over electric brakes
extra strong pillar with a quad bike winch mounted to it & powerred via Anderson plug to back of the ute.
Lots of tie down points & a big stone guard of course.
The guy in the picture is David the Owner of Tait Welding up here in FNQ he has been building off road trailers for 20 years & has it down patt none come back with problems just little modifications or maintenance.
These pics are not my trailer but a similar one i will throw up some of mine as i have changed some things & given him some ideas to do things a wee bit different.
Grumpy
Looks good Towie hope it works just like you expect, let us know how it goes on it's maiden voyage, cheers
Towie
Thanks men i will let you know. As you know the roads & bush up here are scattered with broken & busted trailers.
Towie
Thanks Brian its not a cheap exercise but it should last forever if well maintained.
03hilux
Towie, is this the guy that built the trailers for the boys on All for Adventure? I remeber reading somewhere their trailers were built up that way.
Towie
Good question i dont know but i will ask him. I think perhaps your right i have changed his design in a few ways & he was very pleased for the ideas too.. Really nice fella
Towie
Well its back from being Galvanised it had to be sent to Townsville & its a 2 to 3 week turn around.
Now just has to be assembled & in a couple weeks ready for a test.
Buxter
Nice job Towie
Just remember that the roads to the Cape are fairly good, except for where the bypass road meets the OTT, just after the Telstra Tower. But that was in 2011, and things change yearly.
Buxter
Towie
Yeh im not sure about sleeping on it but you never know :)
I have a 4mm plate ally 4.5m with a 60 Yama on the back. Just finished off the flooring & twin 25 lt fuel tanks also with an 80LB 24volt elec up front.
I will get a few pics of the trailer finished next week the tilt sytem is bloody awesome
Towie
It is Davids design & i just helped modify several things to suit me before we sent it to get galvanised.
Tilt system is very basic & easy in design after trial & error like most things. I will show you in a picture. The rollers are straight with a single piece of stainless used as opposed to many split pins to hold it all together & it makes maintenance fast & easy to replace rollers.
Also the strength in the trailer is to have less angles & keep everything as square & solid as possible. Having the whole roller setup adjustable is so you can tweak & fine tune the setup over the first several uses for example i want it slightly sloping backwards to make launching & retrieving easier when on my own. This way we also get as many rollers as possible under the center for travelling & supporting the boat in as many places as possible.
In theory we could easily move things around if we decided to or needed to put a different boat on the trailer thus being multi use.
What we were trying to achieve is a setup we can literally drop the boat on the beach & wait for the tide to come in or drop it off steep creek/river banks too.
As you can see its very heavy duty & built to last for ever & cop some punishment up the Cape.
Hand winch as back up & to hold boat while travelling.
Electric Quad bike winch powered using anderson plug on tow bar like trailer brakes hooked up to battery in tray.
Pillar is adjustable to suit different loads so towball weight doesnt get to heavy
Simple & single latch to hold tilt system in place, the tilt is controlled using the jockey wheel mounted as in picture.
Jockey wheel when towing is mounted flat next to pillar on drivers side
Hitchmaster D035 which is so simple & solid with full movement.. http://www.vehiclecomponents.com.au/...ler-coupling-1 I had not seen them untill now but i do have to work out how to lock it so it dont get stolen.
I have mounted a wheel hub next to the pillar which i can mount on front of drawbar close to the hitch (driver side) & put spare wheel on thus making it a 3 wheel trailer if i get stuck in mud or sand etc then i can use the truck to winch it or snatch strap it out rather than making an extended or fold in draw bar i have done this before its much easier. Cant see it in pictures as im painting it today.
Independant Suspension coils shocks & wow its awesome
Hydraulic brakes are going to take some playing with to get right but dam they work good.
Walk way down both sides
Heaps of tie down points my cover doesnt fit properly now so have to fix that.
Here are some pics & by all means fire away with questions i know thee is not much info out there on Off Road Boat Trailers and the ones i looked at by Companies were absolute crap for 7K and 10K i really think Tait Welding needs to put his price up alot. He makes these in between doing other things so he doesnt really know what they cost but it took us over 25 hours to put it together after it came back from the Galvaniser.
Then a full day setting it up with the boat on it & getting it rego.
underdog
That tilt system is brilliant! All round beautiful work mate, would be pretty stoked with that.
Towie
Yes indeed Ian its a work of art i could not be happier at this stage.
Over the weekend i have soaked the inside of chaissis rails in fish oil and sprayed the entire trailer with Lanolin now to let it dry for a few weeks before going off road.
We are going to Lakefield NP to specifically check some camping & boat launching areas before taking the boat up there... Bathurst Bay & Bathurst Heads area along with Princess Charlotte Bay.
