Off-road 7x4 tradesman trailer
Heggs
Hey all, I am currently in the process of having an off-road 7 x 4 tradesman trailer built. The idea is to be able to leave camping equipment all packed up and ready to head off rather than the dreaded packing and unpacking.
One of the first things I will be doing is setting up the curb side as a kitchen/mess area and the road side with shelves for camping equipment; I am planning to put a battery or 2 in the trailer as well for lighting and have it charged from the car or charger via an Anderson plug.
Has anybody done anything similar to this fit-out any diagrams or pictures would be greatly appreciated.
Thanks
Heggs
BUSHNUT
G'day Heggs ,
I'll throw a few ideas at you .
Re sink/kitchen area - I would suggest that your wash up area/ sink etc. Be a swing out affair with the sink area at the pivot end because it will be the heavier end and fold down legs at the other end which would be you food prep end . An alternative to having a swing pivot set up is to have a bench that has right angled braced brackets at each end that fit into exterior sockets - your sink can be sunk into that bench .
As far as battery/batteries it depends on what set up on your own rig is . If you have a dual battery set up on your truck then running a normal Engle or the like then the only other thing to consider is lighting , the best answer is now LED then your power needs are minimal , run everything from your second battery . If your power demands are more than that say at a standing camp for 3 or more days then consider solar panels, weight of everything does become the final issue . If your rig is like my current one ( I have a D Max ) where there is no space for a second battery in the engine bay so I have utilized the auxiliary connection on the trailer plug with a beefed up wire running from a Redarc battery isolator in the engine bay to the battery on my Kimberly Kamper and use that as my dual battery . If I just take my rooftop tent mounted on my 6x4 trailer , I carry a second battery in a battery box in the trailer wired up to the trailer plug via an Anderson plug . I can also use this setup to the battery box if I am just going with the vehicle and swagging it , just feed the wiring through the gap in the tailgate .
Re batteries , The purists seem to like the deep cycle for the second batteries , I tend to use the 1/2 cranking ,1/2 deep cycle as they have a two year warranty on them and are of a similar cost to a normal heavy duty battery - on the deep cycle there is I think only one year and they cost a bomb .
The only other thing I can think of the moment is some sort of tarp covering that would cover a kitchen area , you could make do with a reinforced silver tarp with poles fitting into sockets on the trailer exterior with other support poles and ridges away from the trailer .
Hope some of this makes sense .
Heggs
G'day Heggs ,
Thanks Bushnut, how have you wired the second battery through the anderson plug was it just positive to positive and negative to negative?
BUSHNUT
Just the positive to the positive , and replaced the aux wire from the trailer plug with a beefed version up on to an Anderson Socket , the normal aux on a trailer plug is too light negative ( earth is fine ) plenty of earthing point on a trailer anyway , I always chuck a fewfuse points along the way anyway but that is just me . I subscribe to the KISS system every time .
Post a picture of your trailer up then I might have a few ideas there too .
Heggs
The trailer is currently being built for me by a local manufacture, it should be another 3 weeks, I checked out what he had done so far yesterday, it should look good when he has finished it.
It is going to be a long 3 weeks i think :D
As soon as I get it I will post the pics.
Alby123
Hi fellas, regarding deep cycle batterries I have a deep cycle battery in my caravan and yes they do cost more ; in spite of that I have been using that battery for 9 years and it still works as well as it did 9 years ago when I was using it in my 4x4 as a auxillary battery for running the fridge.
As many will say yes they are expensive but they last a long time provided you use the right batterry charger to maintain the battery.
Cheers & keep the shiny side up.
Alby
Heggs
have you got any photos of the finished product
Yes Sorry, here is a few pics of the build, the road side i have set up as storage bins and shelves for tents chairs etc, and the kerb side is the kitchen. we have tested it a few time since this stage and will be doing a few minor mods but so far it works really well.
there is 2 x 60 litre water tanks fitted to the underside next to the axel and at this stage I have only fitted 1 x 80 amp hour battery which lasts me about 3 days with the fridge and lighting, I have a generator that can top up if needed after that.
best part of this is no packing and unpacking, its just hook up and go, makes for a happy wife:)
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
posts
LowLux
Are you, have you changed the tow ball for an off road hitch or is the towball what your going to stick with?
Heggs
Nah the hitch that I have on it does everything I need to do. if it changes in the future then it could be swapped over easily
fronty00
Hi Mate,
I am in the process of doing the same thing i thought a heavy duty tradesman's trailer was a good base to start with.
So far i have stripped the trailer down replaced the factory spring hangers with heavy duty mounts replaced the springs with a better load rating replaced the axle and fitted 6 stud hubs (also used a 5 cm longer axle to allow me to use the neg 10 offset rims i wanted)
replaced all the lighting with LED, replaced all of the wiring.
In the coming days i will be fully respraying it fitting a tool box up front which will hold my SLA batteries i will also be making mounts on the lids for my solar panels so when i am set up i can clip them in and have the batteries charging.
The mounted to the sides will be a jerry can holder and on the other side an LPG tank holder.
I am sure more ideas will come as the build is happening but they are just a few ideas to make it suitable for camping/off road use
345 chippy
sounds like a god build u have going on. couple of things i can give my 2 bobs worth is, extend the drawer bar approx 250-300mm from factory. it will make a huge difference to towing and brakeing.try not 2 load up your drawer bar(boxes, jerrys etc to much) if u can avoid it.
i tow a custom 2ton tradie trailer every day with 33"muddies and extended drawer bar.
also my camp trailer is a 4xbike trailer with 31's, roof rack, slide out kitchen on drawer bar, etc,etc.extended drawer bar.never needed a tregg hitch(or similar)and shes been n sum crazzy angles.normaly towed in on sedate traks and set up base camp.
i cant say enuff how much the extended drawer bar makes a difference.
good luk with ya build.
cheers chippy
03hilux
cheers chippy
I borrowed a mates Cavallier camper a while back, and i found the standard 1400mm drawbar was a bit of a pain. That extra 12inches in drawbar length can sometimes mean having your truck clear of an obsticle before trying to drag the trailer over.
Im in the process of building my own camper, and will be having a 1700mm drawbar. I came up with that figure because i had been out over a few months looking at various campers to measrue and they mostly sat between 1500 and 1800mm.
Heggs
The drawbar issue is like iPhone and Samsung really. I agree anything less than 1400 is far to short and is a pain to tow with, but I also reckon anything longer 1600 is just as painfull. My reasons for this is on sharp hills, drop outs etc the drawbar is always being bashed on the ground as the tow vehicle is on one side of ridge/wash away and then the trailer wheels being much further back are on the other side leaving drawbar acting as a grader in the middle.
But as I started with, I phone/ samsung - same outcome just different ways of doing it....
