Most vehicle jack points are under the vehicle, either under the diffs or control arms if IFS, if you need to change a tyre in the bush you should always try to find level ground, if the ground is soft then you will need to place a sturdy fotting under the jack, marine ply is perfect for this, about 10-12mm thick and 300mm x 300mm square should be enough. Other options are air bags (bull bags), just don't let them touch anything hot or sharp.
