Noise and Shaking from rear of LN106 Hilux
Luke
Ok, so this morning on the way to work my Hilux starts making a sort of squeaking noise from the rear of the car some where
So I jack her up and check to see if the wheels bearings are loose, didn’t seem to be the loose...
Then I check the tail shaft and greased up the nipples a little, and went for another drive, still the same problem, but after about another 15kms as I slowed down for a round about, the whole car starts shaking as I get into 2nd and 1st....
Can you put to much grease into the tail shaft, the part where it slides/adjusts the shaft length???
Can anyone help with possible problems?
Luke
Ok I replaced the Centre Bearing in the tail shaft, no more noise, well didnt get it over 20kph as the damm car is still shaking....
Can anyone throw me some ideas on what it could be??
Luke
If There was a lost weight off the tail shaft, do I need to take the car into a shop or can I just unbolt the shaft and take just the shaft in to get balanced?
