NJ Paj Using Oil
deb_daz
Hi again folks just a quickie I have a 95 Paj NJ 3500 and it seems to be using oil it blows no smoke driving or rev it up and back off I have absolutely no oil leaks anywhere on it.I just cant figure out why and how it uses oil.
Any thoughts would be greatly received.
Thanks
Dazza
road rat
how much oil it all depends all motors burn oil but if its a bit could be your oil rings could be stuck in comp test motor
deb_daz
RE Oil use
Thanks for such a quick reply I really appreciate it I had a complete service T/belt and all adjusters,water pump.A complete service as I have only had it for a few months and I wanted to know all was well with it buying into the unknown so to speak.It has only done 165000 klms and is in showroom condition for its age,Runs perfectly and is faultless.The level was about 3mm above the low mark when I checked it the other day.I would have thought it would last a bit longer than that.
Thanks
Dazza
Davidman
I have a 96 NJ. Mine goes through oil too. I find that if I have been idling for a while in drive, upon take off it blows smoke for a second or two, nothing major though. Have been told, not sure how reliably, that this is an issue with a lot of Pajero's.
bmurray2250
When was the last oil change? When the oil is old and not doing the job correctly with protection it burns quickly. I would change the oil with a Penrite 20W50 (or maybe 15W40 check your manual) and do the oil filter too. At 165,000KM I wouldn't expect rings or value seals to be faultly.
I have been recommended to run a cleaner through the oil to remove old carbon build up.
croozza
Thanks
Dazza
You could be using the wrong oil in it, the same thing happened in the Landcruisers, so they started using a slightly thicker oil and it soved the problem.
shovelboy
Ok Deb_daz i would be doing another oil change and putting in the genuine Mitsubishi Oil and a genuine filter as i have worked with Mitsubishi for around 18yrs and have found that they use less oil if genuine oil is used as they have found a formular that works well and also stops alot of noisy lifters if they are run low on oil also
Cheers Anthony
deb_daz
Again I can only thank you ever so much for all your replies I will certainly be trying the oil change and filters with the original and see how that goes again thanks immensely for all replies I will post and let you know how I go.
Thanks
deb_daz
