Nissian Navara d22 Gearbox
FreshwaterAddict
I have a 04 Nissan Navara d22 4x4 5 speed manual Dual Cab. She's a 3.3l petrol. Anyway, driving on the weekend going around a corner i went from 3rd to 2nd and even though it was easy putting it into 2nd it made like a winding noise. This is starting to happen more regularly now. But as i said before i have no trouble in putting it into gear when either gearing up or gearing down. It just makes a winding noise when gearing down. No crunching noise! Is my worst case scenario a reality? Has my gear box had it?
What are your thoughts on what the problem can be?
If you do think it's the gearbox can you recommend any 4x4 wreckers i can contact where i may be able to get a Gearbox to suit a 04 Nissan Navara d22 4x4 3.3l petrol. 5 speed manual.
Whats the average price for a second hand gearbox?
How much would i be looking at to get a second hand gearbox fitted?
I dont want to go brand new as i plan on getting rid of the car within 5 years. We all know brand new gearboxes for 4x4 are big bucks!
Alien d2
Might be a bearing showing it's age.
See if there is any g'box work shops that could road test it and give you a ball park quote.
They may do change overs to make it easy.
Probibly time to do the clutch too as it's only 1/2 hour more labour as the box will be out.
LazyCamper
FreshwaterAddict, did you find the cause of the winding noise?
Or are you saying the clutch bleed solved the gearbox noise?
I've got an '05 D22 3.3l petrol doing the same thing...
No particles came out in a gearbox oil change, winding noise decreased slightly but still very much there.
