Nissan Patrol lpg problems
Khaosky
Hey guys, hoping someone can shed some light on my problem.
i seem to have a problem with the switch/relay (not sure what it is technically called in the lpg system) when i try and drive my car in gas mode.
she may start up in lpg (sometimes she might not even) then there is a clicking sound coming from the relay(?) which then disconnects the fuel and obviously the engine dies. i have been to a mechanic about a recent transmission service and he had a quick look, but as he isnt registered to do it so he didnt do anything about it, he just managed to hotwire it with a screwdriver and identify that it just seems to turn off unless the connection is forced and held.
am wondering if anyone knows how much this relay(?) is to replace or service? or can i make a connector as am currently on the road with a full tank of gas and no money for petrol!
to be more precise it is the switch that changes the 4b from petrol to gas.
any help will be much appreciated!!!
muc the truck
wiring is practickly impossible to sort out on forum , i can only suguest you phiscaly remove and replace all electical conections traced from the gas bottle and solinoid , relays and look for something loose . a bad conection can criple a vehicle . you do not need to be lpg qualified to work on an electrical part of a automotive lpg system. anyone can within the automotive electrical industry or a mechanic as they all have done auto elec troublshooting to gain there mecahnical trade pass. if its caused from a bad conection you shoud be able to sort it out your self . If you are sure its not loose conection and it is the switch you can trace the wires back from its loom and conect the two together that suply power to the lpg solinoid , this way its still keyed by ignition. if you short cut it under the bonnet this bad as lpg will be on allways. do not short cut it from batery to get you to a repair shop. it must be done via the ignition of the vehicle. any mechanic and auto elec can atleast make it a temporay straight gas car so you can get a new switch if thats al you need.
dom14
Muc is right. You don't need lpg installation license to fix electrical side of the lpg installation. I had my LPG safety switch stuffed few years ago. I went to an LPG workshop and bought it for $40 or something, then took it to my auto electrician and he fixed it straighaway. I also got him to show me how to bypass the switch and run it straight on gas in case shxt happens again.
BTW, the reason the original one was stuffed 'cos the LPG techie wired it wrong. Yeah, that happens, but it's not dangerous, just a headache when it dies in the middle of nowhere.
Not sure, your problem is the same, but it shouldn't be too hard to figure it out. See, if you can take a photo of the safety switch, cut off solenoid, etc and post it here. I'm sure Muc can help you better after that.
cookie64
I am sure the mechanic had the ability to correct it however, it comes down to what he is insured for and if he isn't a registered LPG installer and he compromises any safety mechanisms, which may well be why the relay is cutting out, he may well become uninsured in the event that the car burns.
If you check the coil side of the relay you should get 12Vdc, if not then the problem is further up the channel potentially with a safety switch, if so then you may have a faulty relay - the coil could have an intermittent fault when warm.
Colin
millsy
If it has been humid, or rainy, in Broome, and the coil has a film of dust and crap across the top of it, the signal for the solenoid/LPG 'black box' could be shorting out through the moisture held in the dust across the top of the coil. I think that was the problem I had in a VH Commodore in northern NSW on a rainy day about 20 years ago. The RAA road side service chap just wiped off the top of the coil, getting rid of the build up of dust, sprayed it with moisture reppelant (CRC or WD40) and problem fixed. I reckon the VH had the same symptoms you are talking about.
Khaosky
Thanks guys, really appreciate the feedback. as it turned out it was a problem with the ignition switch which i replaced and have had no problems with the lpg since. i imagine it was the faulty switch which wouldn't allow any fuel through the system, once replaced it was all good! Thanks anyway guys.
dom14
Did you mean the ignition key barrel?! That was faulty?!
