Nissan Patrol Gu 2001
DaNeOs
GU2 - Lifted , Locked , 35s , Custom bar work n everything in between
Nissan Patrol Gu, 2001
Good Points
After having several 4x4s in the past, it was time to get one that was more family orientated having 5 seats. So this car popped up at a family friends car yard, offered me a price i couldnt refuse so i jumped at it.
Bad Points
No real bad points, alot of people will say the 3ltr DI is a shocking motor / grenade but having said that this is just ticking over 300,000kms and running a dream still
What mods have you done?
Engine
Dawes Valve & Needle valve limited @ 20psi
EGR Block
3" Dump into 3" system w/ Magnaflow cat
Racetech EGT and Boost Gauges
Ase intercooler and fan
Bogard turbo timer
Driveline
4 Speed Auto Matic
Bigger Trans Cooler
43% Reduction Gears
4.6 diff gears
Air Lockers
Suspension & Steering
HD Drag Link
HD Steering Arm
Toughdog Rtc dampner
4" EFS coils
4" Rox shocks
Castor Plates
Hd lower control arms
Exterior
Raslarr Engineering -
Front Tube Winch Bar
Rear Bar With Swing away
Weld on style rock sliders
4" Stainless Snorkel
3/4 Roof Rack
Rear Work light / Reverse lamp with Snatch strap mount
12000lb lowmount w 30meters dyneema
Lightforce Genesis 210s x 4
14" Light bar
Interior
Pioneer DVD/SAT NAV/ Stereo
Kicker Comp Speakers & Tweeters
Iphone 4 Dock & Exterior Areial
3 x Extra 12v Plugs up front
GME UHF
Incab Winch Isolator / In out Switch
Rear Draw System
Drop down fridge slide
Modify front bar to suit Hi mount ( little trimming required )
New scrub bars / brush bars
Warn Hi mount - 6hp motor, air freespool extended drum, 50metres rope
Rebuild Auto Trans with Valvebody & 83% Reduction gears in Transfer
TD42ti Conversion
Why did you buy this vehicle?
How often do you go offroad?
Fortnightly
GU IV
