Nissan low beam...missing
banshee
I seem to have lost low beam... High beam works fine. they flicked on and off on low for about a week every now and again and i thought it was just the dust..cleaned the plugs at back of bulb and all good. Trip back from cairns and left one went out....two days later the right one went. Checked power to lights and it doesn't seems to have power going to the low beam side??? i think. by flicking from high to low and using a volt meter to see where the power is going. could it just be the bulbs have blown low beam?? or is there some sinister electrical deamon stuffing with my mind...any ideas would be helpful.
cheers all:eek:
mmmm ok before you ask because i forgot to put it in...94 gq ute.;)
banshee
not sure mate, doesn't look blown and the way which they went out was wierd...getting new ones sent up anyhow, but will check out the relay and replace it anyhow. I haven't hooked up a relay but the previous owner might have...
Gavo
This happened to a mate and it was globes. Remember your car probably has switching earth so may confuse you with multi meter voltages.
