I had absolutely no issues with mine (Dec 2002 Di) but I spoke with one of the specialists at Nissan about them and he suggested poor servicing and modifications were the predominant cause of failure but agreed there were some issues with the earlier units.
cheers
Yep, its always the poor bugger fault who drives the car.
My Patrol is the most over serviced car I have ever owned. I put engine oil in it which is designed to do 40,000 kays in long haul trucks and I dump it after 5,000-7,500 km.
What sort of modifications are we talking here? Putting a roof rack and bull bar on? Surely you can't blame all failures on putting diesel chip in.
Infact there is anecdotal evidence that more ZD30 grenades were the one with stock no mods.
The issue is well known. Cheap arse cast alloy pistons with questionable shape/design, poorly implemented EGR strategy with even cheaper arse solution combined with "unlikely" scenario of cruising long distances at high speed is what burns the holes in the pistons hence the "grenade" monicker.
Nissan response to excessive heat in combustion chamber is none.
Early models were caught out with low amount of oil in the sump (5.6 L) so they had oil starvation issue, Nissan fix was to cut down dipstick and pour more oil in (8.2 L) with no so clever consequences.
With more oil in the sump (same size) there is more blowby so existing breather can't cope and sends oil vapour on its way in to intake manifold where it mixes with hot exhaust gases (non cooled EGR in hot climates WTF????) causes all that oil to carbonize and start layering intake ports reducing the fresh air intake resulting in AFR being rich hence increased exhaust temperatures.
Add to it not so clever fuel injection control (MAF only) combined with boost control from "stone age" and...
You can see where this leads .....indeed most if not all grenade failures are simply just a hole in the piston usually one close to EGR ports entry.
That's all what goes wrong but my! Does it cost a pretty penny to fix because whole engine has been designed and built like Lego and Ikea sets.
CrD ZD30 has much improved(if not superior) fuel injection control (MAF + MAP + MAT) much better pistons and induction system and cooled EGR.
Results are in: CrD ZD30 is no longer grenade.
