NH Pajero issues
xboxice
Hi guys picked up this pajero and up on driving it back to Newcastle right at the Twin Servo
i lost power steering and very bad noise coming from the engine bay and A/T temp light on
pull up in a parking spot to have a look and realize the drive belt was not turning, the pully that connects to the crankshaft is just dangling around.
Mitsubishi Pajero V6 – crankshaft pulley issues
xboxice
Thanks Billy i went back with some tools and got it sorted,there is still a funny noise coming from the engine when AC in use.
prawns
Maybe check your AC pulley is still ok if its a screeching/squeeling noise? (replaced mine recently)
Pretty easy to do, 15mins and its out, stick your finger in the middle of the bearing once its out and spin it in your hands, shouldnt be too noisy or have excessive play
Be interested to see if your AC pulley is plastic like mine was - I replaced mine with a metal nuline OEM pulley and the old plastic pulley had signs of rubbing and was noisy when spun in your hands and pretty flogged out (not sure if mine was a "original" pulley or not as the supposedly original OEM replacement was slightly different on mine)
To remove the pulley - loosen off the bolt in the center of the pulley (its a lock bolt to lock in the pulley tension) Then loosen off the adjuster bolt until you can remove the belt, then completely remove the bolt in the middle of the pulley and off it comes
Dont try to adjust the Tension adjuster bolt if the center pulley bolt is done up tight - It must be loosened off for the tension adjuster bolt to work
I got a replacement kit to replace the idler bearings and AC pulley in the one kit from ebay
$129 it cost me for both idler pulleys and the AC pulley if yours is also flogged out
xboxice
Tell you what your spot on the ac belt need replacing its dancing all over the place :)
question where is the thermostat on my NH :)
prawns
Your thermostat is at the end of your top radiator hose :)
Its good to know yours was a metal pulley - I had suspicion my old one wasnt the correct one installed on the vehicle (brackets slightly wrong too so I think my brackets arnt quite standard either)
My rig had bits and pieces put on it from various cars when it got rebuilt I think ("make it work" parts lols) so that would explain that I guess.
I noticed your PM mate - I will send you a link to the kit I bought - It was fairly recent so should be the same price :)
xboxice
install thermostat and x6 spark plugs today truck is running smooth now.cant believe having a bad thermostat would result in sluggish running motor :) anyway this happen at the Nauru at Belmont this afternoon.
lol this is my first 4x4 btw guys ") 1993 Pajero stuck - YouTube
nhpaj
I just recently sold a nh but a few months ago i was driving along minding my own. All of a sudden this wild noise coming from engine bay, then the sound of a rather solid piece of metal hitting the road..... ac pulley mounting bracket snapped went bouncing around everywhere. Haha Needless to say there were a few expletives.
