Newbie 4x4 - Diff question
Tristan Botha
Hi there,
Bit green to all this and a bit unsure.
I have a Holden Rodeo LX 2.8L Diesel Turbo and it has diff lock on it.
On the gear stick for the diff it has 2H, 4H and the 4L.
Can i put it onto 4H without locking the hubs????
Or will i need to lock the hubs before i can put it into 4H?
In other words, if i put it inot 4H without locking the hubs, will all 4 wheels be pulling or will it damage it?
Thanks for that
Stew70
Hi Tristan. If you want to use 4H or 4L, you must lock the hubs. If you dont, it'll still be like 2 wheel drive. No drive from the front.
bmurray2250
Agree with Stew, if you need 4x4 engaged lock the hub first. A good idea is to engage them on rough tracks and drive in 2H until you need them. You can do that on the hard sand too
rodw
But selecting 4WD 4H or 4L won't damage anything, but selecting 4H will serve no purpose without hubs locked. If you want to select 4L, it it pretty pointless doing it unless you have all 4 wheels doing the work.
As BMurray says, it is quite acceptable off road to drive in 2H with the hubs locked and then you can engage 4H without stopping when it is required. However, don't drive in 4H on the buitumen as diff wind up will ocur. You usually need to stop and select neutral before selecting 4L unless you are very good at that forgotten art of doubling the clutch!
Brisey
As BMurray said it is a good idea to engage the hubs before you need 4 wheel drive as sometimes you may be in the poo already when you need it. Also it gives the diff a bit of time to spin the oil around & warm up before you use it.
Bri
MGWREF
On one occasion i had to manoeuvre a large boat up a steep narrow driveway. Pulled 4L with from hubs unlocked, brilliant nice and slow and the clutch loved me.
Stew70
Yeah I've heard that too. I know somebody that tried the same thing to back a caravan. So much easier.
BILLBY
locked hubs and turning circles
will be directly affected by selection the of the slow box , you may need to change your turn in spot and exit point and might even have to have a couple of bites to round a turn normally done in the big box,I like to hear people engaging the front hubs especially to stir up and warm the oil, a lot of city 4wds the oil turns to sludge without use and something to maybe be looking at when buying .:cool:
