theres also some free versions of trackers etc around - perhaps try a free one for a while - then you will know what kind of features your after and can make a more informed choice on what program you want to pay for based on features you use
All you need to do for "tracking" is install the program, load the program up on the tablet and select "start tracking" or similar - the program will automatically use the built in GPS chipset in the tablet to record your movements (make sure it has one....)
Some programs will require you to download maps for your area first so that the tracker will still show a map when outside of mobile coverage - other trackers will download the maps you need "on the fly" as your driving around but this wont work outside of mobile network coverage (and it uses your phones internet plan)
Trackers dont really need a map to track whatsoever though - the tracks are really just a text file full of GPS co-ordinates so some of the free trackers wont even show a map or they just use a free map source like google satellite hybrid/satellite/maps which can be used for free
Generally the tracks recorded using any program can be transferred over between PC/MAC/iphone/ipod/android etc as long as they are recorded in a standard kind of format like GPX,KML etc which they usually are (some programs will give you a choice what format you want to record the track in, be sure to select a format compatible with other programs you might use - GPX is usually the most compatible with things ive found)
