New to 4x4
#1
Hi guys, new to 4x4, quick question I have a XRS-370C CB / Scanner in the ute, can I put two antennas on it to improve the scanning side of the system?
Tink
Welcome to Earth. Sorry no idea what you are talking about but I’m sure someone will know and give an answer.
Tink
Ditch
Welcome to the forum.
Adding another antenna will probably make it worse & it would require a matching network to make it work for very little gain. You would be better off investing in a good high gain antenna instead.
Chatty
What @Ditch said...
Invest in a good antenna to start with, rather than trying to phase match two antennas - if you get the matching wrong (which will be most likely 99.9% of the time) you will definitely make reception worse and run the risk of blowing output transistors on transmit.
You would be relying on trying to match two antenna and lead lengths to sub-millimeter accuracy.
