New Suspension
hiluxdriver
Need some more info champ. What car is it? Where do you do most of your driving (hwy/off road)? Are you looking for a lift as well? Where are you? What is your budget? I know bugger all about suspension but this info will hopefully help someone that does know something.
conanlovegrove
I have a Holden Rodeo RA Dual Cab Turbo Diesel 4x4. I want no more than a 2inch lift, I do most of my driving on the highway but I want something that can take me off roading if I want to. I have a budget of $1,500 - $2,000.
Cavsarge
I have fitted monster rides to my hilux which is a bit more pricey but came with all of the diff bracketry etc and is hieght adjustable, had a good run out of tough dog on my last truck but others have less good things to say about them.
Most of the major brands/suppliers should fit the bill but you need to make sure that you specify what the use will be- my first set of rear spring were to heay in the ute and it rode crap until loaded to the hilt day to day.
Regards
Bernie.
HHewitson
Ironman suspension, it's the goods. It's what I have with 2"lift leafs all round and I paid $1600 fitted on my landcruiser
muc the truck
I am looking to upgrade my stock suspension, can any recommend something? I am on a budget.
First of all remember this . suspension travel is everything. Too many buy such stiff springs they are worse off than standard for suspension travel . Your vehicle needs to be able to compress the springs under load and if it cant you get a wheel off the ground sooner than you did before .
Don't be too greedy for lift because its travels enemy because most give you the lift by going firmer and harsher ride . I have jacked a patrol up off the ground from the drivers side hub and lifted the passenger wheel off the ground after jacking it just 3 inches. Don't land yourself in that territory. He tossed the springs in the metal bin and bought dobinson flexys .
knakkers
I currently run OME on my GU Patrol. Great suspension very happy with it, but also it is on the high side of people's budget.
I actually work for NGK Spark plugs, which are the only distributors of KYB Skorched 4's in Australia. I already had my OME suspension fitted before i worked for NGK.
KYB Skorched 4's are bang on the market for quality & price, their lift kits don't supply all vehicle tho. Their springs are totally on par with King spring coils & Tough Dog leaf springs.
Have a look at KYB website or NGK website or ring NGK & ask for Jason in the engineering department, he will give all the specs on the KYB lift kits. Hope that helps
Sent from my GT-N5110 using Tapatalk
knakkers
If your going to spend the money, make sure you do it right the first time. DO NOT look at cheap Chinese or other made stuff, coz it will fail, springs will sag quickly & you will not get the ride comfort.
knakkers
Doc is right. You can't leave standard height shocks in & put lifted springs in
Tappet
So long as your standard springs have not sagged and are serviceable. Consider spending most of your budget on shocks. In the long run you wont regret it. Down the track if you feel you need to lift you can go a raised spring at a latter date.
Aussie made is good, yes. But don't write of the likes of Bilstiens, Koni or even KYB. Those manufacturers really know what there doing.
Rigger64
Well i just did a 40mm lift on my 1996 Suzuki Vitara it cost me $896 from Ironman & i very happy with it.
Springs, Struts & Shocks
Hotdog
I've been happy with Ultimate suspension on my Hilux. I fitted standard plus because I was worried about getting my truck in the garage.
Ironman 4x4
Hey Mate,
If you'd like us to provide some advice on the best setup we could offer you based off your needs and budget we'd be happy to spec out a kit for you.
Just shoot me a PM and we can go over all the details of your vehicle and what you do with it.
Cheers,
Matt
Ironman 4x4
cookie64
I've run Old Man Emu (OME) in my past 3 4wd and have gone everywhere with them and they have not disappointed, make sure whoever you get asks some very pertinent questions.
Like where you intend to go, if you have drawers or not, long range tanks, what sort of weights you are likely to carry. This all makes a difference in the components to meet your requirements. I have seen quite a few instances where the above hasn't been asked and they have had to go back and buy bigger / stronger stuff when they have loaded up.
cheers
