hiluxdriver
Spent the last couple of arvos doing a couple of little things I'd been putting off for a while. Anderson plug to the rear from the aux batt, and relocated and changed the trailer socket.
Cable for the anderson is 6mm twin core with a 20 amp maxi fuse at the battery, that runs down the passenger side firewall to the middle of the car where it's cable tied to some other fixed lines above the tail shaft, up over the rear diff, around the fuel tank to the back bumper and an all weather case.
Original mount for the trailer socket hung from a bracket that made it sit below the tow bar. Great for dragging on the ground when 4wding, but I didn't really want that. Grabbed a new plastic plug, drilled a hole in the bumper right in front of a fixed steel bracket behind the bumper (should have looked first - where the grey hole is). Drilled some more holes in the rear bumper to flush mount it. If not for the crap first hole it would look almost standard.
