New Memory Map for All
Just went into the App Store to check for updates
updated and now have latest map set at no cost. This makes the Hema version better than the MM if you don’t have to pay for updates and can still insert any other maps you want via your MM account
Hi Kevin ,can you clarify about this 2022 update as i have the Hema 4wd on my ipad and i can't see any new updates for it neither from the app store or from there Digital Map Store. Cheer's
in my App Store the other day, it highlighted Update for the app, so I now have the latest.
also, yes the outback can change, especially with all the new mining roads changing our countryside
smitty_r51
Reading the app reviews on Android it requires Memory map to be installed anyway and is just another layer over the top :|
Any confirm that? been running MM for years with the 2018 HEMA map pack, can upgrade to 2022 for $49, or could spend $99 for the HEMA layer and then hope they put out three lots of updates
Check out the new MMFA app, it is streets ahead. But you will be stuck with a $49 upgrade every few years. The good news is that you can also run the maps on MM for widows and print the maps out.
Andrew A
Maybe im not getting any update notifications because i'm using an old hand me down ipad on 9.3.5 and its not compatible to the new firmware . Not an issue as my main Nav is Oziexplorer.
The minor changes wouldn’t make a difference I don’t think, go into the App Store and see if it will update?
Andrew A
The Latest Version requires ios 11.4 plus. The reason the download button doen't show in my case as my old pad runs 9.3.5.
smitty_r51
Installed it on my old Samsung S2 tablet, logged in and it downloaded all the maps i already had bought. Bit fancier layouts etc but not much difference, old version is still installed anyway so i can swap between them.
