Neerim Saturday 16/6/2012
OutBacker
This was a mini trip. The aim was to give the new Silverstone MT-117 Xtremes a run and get some mud under them and to take Digger1982 out on trip number two.
Rendezvous was at BP Longwarry at 8AM. We even managed to pick adjoining bowsers before we'd even met. I was driving my GU and Digger1982 '92 Hilux twin cab. Given it was Digger1982's second trip ever I thought it was best to take it easy on Young Track. Last time I was there it was a nice 2WD adventure forest access road. Well in the two years since I last visited it has gotten a lot worse :) It had ruts and puddles to play in and has progressed from 2WD access track to a nice warm up track.
Managed to throw my navi Steve around on Young Track. He'd never been in a locked 4B before and I plowed into the deep part of a mud hole locked front and rear and he braced for the fall in but wasn't expecting the Patrol to hit bottom and throw him back like it did. Patrol 1 and Steve 0.
We turned to the right where you can continue on to Hard Up Haul. This track has always the ability to be difficult in parts. So we went in prepared for that. The going was pretty good. We came to some of the deep holes. I knew they were deep two years ago, I had 35's now so thought I'd give it a go. Well the step was a little steep and all I managed to do plough mud with the bullbar. Enter the GU mud plow. Two goes and no progress, time to put it in reverse and take the chicken track.
We then came to the 3/4 way fork in the side track. We decided to get out and reccie this one. The decision was to go on the right hand descent and then take the bottom track. I went first a slipped a little on the way down. That made Digger1982 a little scared. 35's xtreme's slip like that what will worn 33's be like. Knowing the way that the track slipped we picked a slightly different line and Digger1982 made it look easy.
While up the top Steve and I heard a hissing sound. Put it down to the air being expelled when I turned the lockers on and off. At least that is what I thought it was. Short and sharp air hissing sound.
We went a bit further on and we came to another section that had a soft chicken track on the right and a rutted section on the left. I knew the right was soft, but thought I'd cut a track for Digger1982. Well that didn't quite go to plan. Those Xtreme's just chewed up the soft chicken track and got me stuck.
So the plan was to send Digger1982 on the rutted left hand side and then hook my rear facing electric winch into his truck. Digger1982 ended up getting a little stuck and needing to winch up a bit. In the process of climbing this part Digger1982 even got some panel damage. Gotta have a souvenir to take home.
This was also an opportunity to bring out the new Stihl chainsaw that I got. There was a stump that was hindering my progress up that needing cutting. So we got rid of that before winching up. The rear mount winch worked a treat on Digger1982 and it was the first time that I had used it to recover my Patrol.
The next hairy bit was just after Young's rock, the track that heads to Young Track. I made it up without drama and Digger1982 needed to winch up hooking onto the Patrol. All in all it was a good first track. We had some food and then headed out to Beards Rd before attempting Hard Up Haul (going up).
At Beards Rd I decided to check the air pressure in my tyres again and discovered that the front left was down 10PSI but because it was only 22, I decided to be lazy and drop 10PSI in the front right to match.
We drove Beards to Hard Up Haul and commenced Hard Up Haul. The top part of the track was bone dry. Not very challenging. Anyway once we commenced the downward sections it got a little rutted which made the trip interesting. We then came to the steep and rutted section that I promised. It was very slippery where the stream crossed at the bottom. We had about 4 or 5 sets of wheel ruts to chose. We decided to get out and have a look.
Steve and I thought that we'd take the left most set. I hopped in and got a little hung up coming out of the stream. Lockers on and I got through okay. I got about 40% of the way up on the right hand set and got hung up on the diffs. So back up and try the second most left set of ruts. I got a bit further but still bottoming out on the diffs. So this time we tried the right hand side ruts and I managed to get all the way up. Lesson #1 xTreme tyres are great but some ruts will always be too big.
Digger1982 armed with knowledge of line and tactics did a much better job of that section. He was also surprised that he didn't get stuck climbing that section.
We then continued on Young Track back along where we went earlier in the day.
Once we reached Beards Rd we decided to have a look at Fenceline track. It was getting a little late but a bit of a look wouldn't hurt. I checked that leaking tyre again and it was 22PSI. So no leaking air from Hard Up Haul. Yay! We were driving down Beards and said to Steve great about that tyre not leaking, when all of a sudden we hear this hissing sound. Talk about Jynxing yourself. So we pull over and sure enough there is air coming out from the bead. So we pull over and decide to try and do a bit of a track side repair. I had a spare but it was for the other side and c'mon these were new tyres FFS. So we jack up the Patrol and let the air out and try and clean the bead with a small screwdriver and some water packed earlier that morning (what a great idea that was, you never know when you need to refill a radiator). No fix. I then remembered that in the box for the new impact wrench I purchased there was a small tyre lever. Jackpot. So clean her out and pump her up and she was as good as new. It was at this point that I heard Digger1982 mutter the words McGyver. It just goes to show you can never have too many spares and you can never have too many backup plans for your backup plans.
My navigation sucked so we ended up taking the long way and entered via Brigg track. The track was simple, then a little bit slippery and then it started to get steeper and more rutted and it also started to rain a little. It was about 4:30PM by this stage and light was fading. We reached a section that had a large fallen tree and some really soft stuff in front of it. The chicken track proved to be quite difficult for us to get on. Just past the tree we reached a really steep section with a very large puddle at the bottom and a very steep incline on the other side.
Steve and I jumped out and decided to investigate on foot. We called on the UHF for the others to come down and take a look. By this stage we had a bit more drizzle and lots some more light. We really wanted to do the next part but it was getting dark and the concept of spending all night winching up this hill didn't seem that appealing. So we decided to turn around and save this for another trip.
As luck would have it Digger1982 stopped at a point made for doing U-turns on a narrow track. So we managed to turn around quite easily. However the climb back up to the fallen tree seemed quite ominous. Digger1982 made it up without a problem. However I didn't start the climb on a good line (probably should have reversed up and taken the same line as Digger1982, but I have 35's and can bash my way through) and this resulted in me getting all crossed up. I crashed down hard on top of the ruts. Locked front and rear and going nowhere. H'mmm this is not good. So decided to call for a winch. So Digger1982 comes back down in reverse to render assistance.
Anyway I had a moment of clarity. How could I be locked front and rear and have my front driverside wheel not spinning. Either my locker was broken or 4WD wasn't working. I had a look on the dash and the 4WD drive light was on and the stub lever was in 4H. I decided to go to 4L and bugger me dead I pulled out from being crossed up. Lesson #2 sometimes auto hubs unlock under extreme load or jolts. I had never seen this before, just heard about it from old blokes.
I managed to drive up another 5 or 10 meters before getting stuck on the diffs again. No forward or reverse moment and all four wheels spinning this time. I was definitely stuck. Laziness clicked in. Let's connect mine and Digger1982 via a winch extension strap and use his winch to pull us both up. Well that didn't quite work as I was too stuck. So we bit the bullet and carried the rear mount winch up to Digger1982 and hooked that up. That proved to work in the end, but only just. I was that stuck in the mud that we were winching Digger1982 towards me even with his winch holding him. Lesson #3 don't be lazy, get off your bum and haul that winch up the track!
We had a couple of minor hairy bits but on the hole it was a simple trip out.
It was a great little trip, we got to introduce Digger1982 to the fun parts of Neerim, give the new tyres a run, use the chainsaw, do a couple of winch recoveries, a trackside tyre repair and most importantly get out on the tracks and have some fun.
If you have read all of this trip report you've done well.
shinysideUP
Great report mate. Love going out to Nerrim. How much did you pay for the extremes? Where from and what size are they? If you dont mind me asking :D. Thinking of getting some myself.
OutBacker
I got 35 X 11.5 R16 for about $320 ea off evilbay. Didn't seem like a bad price. I know the 33 R15 go for a lot less.
They are good fun, but very loud on the blacktop as you'd expect. Also when you are coming to a stop on the blacktop it feels like she is gonna stall because you get a bit of a shudder. Lucky I have a set of road tyres.
I'm sure there are better tyres out there if you're prepared to buy something more expensive but for the price they're a ripper. Just don't put them in the soft stuff. Also they spit up some nice large chunks of mud, so keep the windows closed.
Digger1982
Wow!! We just found your trip report on the forum and are amazed that you have such a great recollection of events and envious patience for writing in such detail! Thanks again for an awesome and eventful day out! We learnt lots and had fun in the process. Neerim made out trip to Jamison the previous weekend, look like child's play lol. Hope all is well and we'll have to do another trip soon.
