need some info on phone aerials
RoughNReady
G'day. There's really no suitable place for this so I just wanted to ask about mobile phone aerials. I'm sure at least a few of you must have car cradles with an external aerial.
My phone doesn't have a phone plug so it'd need a passive patch setup. I worked this much out but beyond that I have no idea. Apparently there are cradles and separate passive patch coils that can be shifted to be closer to the phone's internal antenna? I don't really know what to look for.
I also have a more insidious use. I want to attach it to a phone tough case to have a passive patch setup and external aerial, probably poached off an older phone or even a small car aerial.
I know it sounds insane but I'm sick of 0 to 1 bars reception and doing the signal hunting ballet. I can get great signal in other areas but in the 30 or so km around home it's tragic. Of course I spend most of my time in this area. If you are wondering there is a tower located 2.3km away from home as the crow flies. besides a grain silo the tallest structure is a couple of two storey houses, and the terrain is as flat as a pancake.
You know it's bad when your phone connects to a tower in a town 30km away sometimes because the signal is stronger.
Anyway enough whinging. I can't work out the finer details of doing this. I guess anyone knowledgeable on phones or even HAM setups would know better than me.
chris_stoffa
I have an Electrophone mobilephone antenna mounted on the bullbar that I hookup directly to a patch port input on a Samsung S2 that lives in the glovebox with USB power cable solely for remote area use. I simply swap sim cards and the reception is phenomenal - if there is a tower out there it will pick it up.
IIRC The S2 was the last Samsung to have a direct patch port
Might be a possible solution for you
Chatty
The S4 had ports as well - but being 4G it needed two external antennas, which was a pain in vehicle.
chris_stoffa
The S2's once the external port has used more than a few times ( you have to push the connection on quite firmly) tend to break the connection to the internal antenna making it very suitable from then on in as a stand by / external antenna phone only -it will only work with the external antenna:D
RoughNReady
My phone doesn't have a patch port. Probably one of the first I've had which doesn't. It gets great reception elsewhere though. Better than my previous phones. The fact that it gets 1 bar or 0 without total loss here is testament to that. Still it didn't stop me from contacting and complaining again about their useless tower.
For the real sticks I could revive one of my old ones that isn't too far gone, but the simple truth of the matter is that I bought what I did was because I needed it. Really I hate the reality of it but I constantly need to be on top of email, calls, appointments etc. etc. even when I'm at home or out and about doing other errands.
I'll have to hunt through the pile of deadies and find one with a connector that can be fixed.
While I'm at it I'm irked that i can't use the tough case I bought. Even though the back of it is mostly a silicone honeycomb pattern it's just enough to degrade the tiny signal to non-existence. Pity. Flipping through the glossy thing that came with the case for various models it even suggetsed it's use as a safety hammer for breaking car windows hahaha.
Still, no hurry anymore. The beast is off the road. Took it for rego and I have a few things to fix.
red hilux
I have an iPhone 5, I also have a smoothtalker cradle, 7db high gain antenna mounted to the bullbar.
I'm using passive induction as the iPhone doesn't have a port.
My on road experiments comparing to people with no antenna. The results are almost no different.
Not worth spending the money on it unless you have a direct connect port.
Only once did I only just have reception behind a sand dune when everyone else was out.
The smoothtalker cradle is great as hands free cradle. Solid construction.
https://www.telcoantennas.com.au/site/catalog/patch-leads/mobile-phone
Blue Troopy
I have an I Phone too.
The cradle is really a waste of space, best to buy an old
blue tick Telstra phone and a sim adapter for bush use.
I use a 9 dba stick antenna and get coverage in most areas.
I've had a few inductive cradles and bullbar mounted antennas on a few phones and every one has been useless. As others point out, no better than nothing at all.
The only solution that worked from me is to get an old blue tick phone with an external antenna. I used the T100, then you MUST put a reasonably high gain antenna ( 6db - 9db) ON THE ROOF. 477mhz UHF suffers enough that it shouldn't be mounted anywhere than the roof, but 850mhz is worse.
Lately I have given up with the whole concept of an external antenna. With a good blue tick phone, standing on the bull bar or moving 100m seems to work every bit as well as an external antenna. Of course it is difficult to stand on the bull bar at 100kmph, but if the reception is that bad it will drop out anyway while driving.
