Depending on the GU model you have, ST or DX, they have an electric aerial. Check your console to see if you have an aerial switch, mine is located above the stereo on the left. From what i recall, the motor extends the aerial until it gets resistance, then stops. Nopticed this when it got bent a few months back, it only went halfway up each time. Strightened the kink and it now goes all the way out. But if there is no aerial for it to extend, the soloenoid may keep clicking on and off as there is nothing telling the motor to stop?
Otherwise, check your dual battery setup (if you have one). Redarc is notorious for clicking when there is an issue, especially with voltage drop on either side. Mine clicked for about three weeks after the fuse blew out on the alternator feed line, the voltage in the Aux batt was higher than the one coming from the alternator so the solenoid clicked on and off about every 6 seconds, clicking back in to test and then clicking back out again. Took me a while to isolate the issue, as internal voltmeter was reading battery as full, when solenoid was on it showed both sides as 12.6V.
Other than that, try to isolate by turning off systems if you can one by one. Secondary power supplies, stereos, CB's, fog lights, anything that might run off an isolator or solenoid until it stops, then that should be your culprit.
