need halp asap - Car wont start
WTABUZ
Hey all.. In the process of converting my 2.8D lux to turbo
Car was Supercharged so bett was mover to pass side of bay.. My Das has taken off charger and we have put a turbo set up on. He moved battery back to drivers side. Now when we turn key starter motor just ticks once. We took it out and replaced starter motor with a near new one .
Any ideas or does anyone have a link to wiring diagrams we can look at to see if we have forgot a wire
thanks
offroad80
(Don't shoot me just a suggestion). To me it sounds like you might need to check both earth and power cables are connected firmly at each end and that the connections are clean. Only suggested this as the starter is making noise so sounds like not enough current getting through to the starter. BUT I'M PROBABLY WRONG.
Dave40runner
Is the earth strap still connected? Check to see if there is a thick wore going from the engine block to the chassis.
Sent from earthling #3 on my CD V6 Jelly Bean powered HTC One X using the send button on your mum's Tapatalk 2
WTABUZ
Cheers guys. Traced ecerything back..Worked out it was 2 things , the power cable to starter had been joint , the conection/joint was not connected 100% and the cable was bit to small.. got a new thicker cable , started firt kick
