Theirs a simple rule with patrols if you want it to drive like shit put cheap shit in it .
As rude as that sounds it is true.
Patrols do not have good geometry for road manners once lifted so the important thing is to do what is needed to make them drive right.
Firstly to answer your questions dobinson is good and is far in front of Iron man for patrol suspension , heaps of guys talk up iron man purely because 2 reasons, first is they havent tried decent suspension so they do not know what a good driving and performing patrol is like,and the second is if they are a reseller they are getting around 100% markup so why wouldnt they say its awesome.
Just go and have a look at any competition and see whos gear the pros are using and you will see the highest percentage is ours ( superior engineering) by far, its not because it is the cheapest but it is the strongest and best performing.
Onto some basic tech.
The kingpin inclination on a patrol makes a standard height patrol drive extrememly well but unfortunately if you do a lift and get the caster wrong as many guys do you will suffer the dreaded headshake , at a 4 inch lift guessing you are going to run 33's caster plates that iron man would sell in there kit will be way too much caster , now this may be okay when the kit goes in but within a few months you will experience first hand what headshake is , on the other hand 3 degree bushes would work okay as taking in the consideration of 33's. You could use 3 degree bushes and this would work okay and allow for any sag in the springs but dont forget you lose wheel travel from the bush offset , it doesn't matter what brand of spring you use it will sagg it just comes down to how quick.
Drop boxes that dobinson sell would probably be ours but not certain on that, they are made for 3 3/4 lift to around 5 inch , they are a good choice as they will out perform caster bushes and radius arms and way ahead of plates. Our personal choice would be a radius or super flex arm purely because you wont loose flex and you keep maximum ground clearance and i have never seen a failure . So there is your caster choices.
Onto the drag link , this needs to be replaced with a good strong unit that is adjustable , factory units cannot be adjusted, the most common is the 4140 comp spec. This needs to be replaced so you can get steering back to full turns either way.
coils are basicly choose the correct ones, this comes down to the salesman or yourself.
brake lines- braided is better , rubber is cheaper.
Shocks make or break the truck , the biggest thing in the industry for 4 inch lifts at the moment is remote res shocks because there is no comparison to any type of foam cell or twin wall, those cheap shocks that are made for around $15-$18 cannot perform to the same standards, but if you are on a budget than my personal choice would be the dobinson's, they are a nitrogen shock that will resist foaming and they are valved to suit the patrol , at the end of the day shocks are a personal thing , what some like some hate.
Damper is just that, it is just there to dampen the steering so a standard 35- 40 mm bore is good , my opinion is stay away fro RTC's but thats my opinion only you shouldn't need an rtc if you have followed my rules on caster as your steering will return to centre itself.
4 inch lifts you should be fitting adjustable upper arms or longer lowers (ute) this is because the 5 link geometry as you lift the truck 4 inchs the coils will bow backwards towards the shocks , thus bowing the shocks putting additional strain on the shocks , plus remember as it articulates it kicks the pinion high and this exagerates it even more. Thats the most common cause of premature coil and shock failure.
You need to fit a bracket on your proprtioning valve , if you go up 4 inch you lift it 4 inchs - failure to do this means your brakes wont work properly.
here is a bit more reading -
http://www.superiorengineering.com.au/index.php?pag_id=30
pinion angle measurement
http://www.superiorengineering.com.au/index.php?pag_id=115
steering rods
http://www.superiorengineering.com.au/files/File/suspension+fitting+for+patrols.pdf
fitting patrol suspension
this link shows a lot of different option that you may understand that there is alot more to a suspension kit that what you have first thought.
http://www.superiorengineering.com.au/store.php?cPath=31_32_33_179
I have just done a breif description and there is parts i hve not bothered with explaining as i could just keep going and going , hopefully it has helped .
Mick
