Mystery hose on top of gearbox
2freeq
i just recieved my new manual gearbox for my 93 paj turbo diesel. gearbox and transfer case are exactly the same except for one hose, the new gear box has a rubber and metal hose coming from the bottom of the 4x4 selector lever going into top of gearbox then back out same place and finally ending up next to bellhousing like it attaches to the body. on my old gearbox where hose goes into it it is blocked off with a rubber bung and there is no outlet/inlet nipple on the transfer lever like the new one.
is it just a breather? or a vaccuum? or a oil line?
basically do i need it or not? sorry for the poor description i can get a picture if need be.
cheers.
Paul
2freeq
this is where it comes out of the transfer select lever (this is not there on old box)
this is the T-piece into top of gear box (this has a rubber "bung" on old box)
prawns
me2 (just cause I cant imagine why oil would be pumped into the rubber boots for your shifter)
croozza
Where does the 2nd part of the hose go to after the T piece.
I have heard that there was a problem with those gearboxes, as they use to pump oil up and out of the lever linkage, this could be Mitso's solution to the problem
2freeq
yeah it could bolt to the bellhousing. im guessing where it goes, like i said the gearbox that came out didn`t have it so i have no idea (not that i had much of an idea to start with) lol never changed a gearbox before, let alone at home on uneven grass with VERY limited tools and even less knowledge. haha getting there though, who would have thought a 100kilo gearbox on a old crappy trolley jack would roll on grass so i can manouver the box around under the car. lol
