wreckingball
Thought I'd show my diy solution to a storage setup in my 80. It consists of a shelf 300mm high that sits between the fridge and the wheel arch it runs from the tailgate up to the 60l water tank that's strapped to the cargo barrier. on the other side of the fridge is a partial board shelf with a 9l tigerz 11 air tank which is filled by the typhoon compressor that sits between the fridge and the barrier then after my wife declared that she wouldn't be going camping again till I made the fridge accessible without unpacking the whole car I came up with a cheap top shelf I got hold of a couple of shelves from a double door commercial drinks fridge they're 1000mm wide by 500mm deep so not quite the full width of the car but good enough . I attached it to the cargo barrier via 3 hinges bolted through with a plate to form a clamp. then I've used a couple of cam lock straps through the rear grab handles to hold it up. I then cut one shelf to fit vertically between the top shelf and the top of the bottom shelf and used 8mm cable ties to hold it at the top where it fits nicely between two of the bars and at the bottom some 90°angle brackets hold it in place with more cable ties .now for some pics.
you can see here that I've used another small shelf to take up some of the space above the fridge its a neat fit for my first aid kit and some other bits and bobs .Since the first pic I also added a second vertical wall to protect the side window and stack stuff against. It makesmakes packing the car easy now .
