G'day again,
Yeah, I think Kickass look pretty expensive nowadays. They used to have a big pre-christmas sale and I saved a heap, but it would be a lot cheaper to make your own box. Their 8 B&S leads used to be very cheap, too. Solder or crimp, their is a lot of debate about what is best, or you can do both! It's all pretty simple, just sort your tools and some space first, there's a fair bit of cutting of wire lengths, stripping, etc.
I've got a solenoid switch hooked up to my alternator, so I only get power to the rear battery or anderson plugs when the engine is running, but yes, most dcdc chargers have an isolator built in. I didn't bother with a VSR (Voltage Sensitive Relay), just a straight solenoid on and off. They seem to play up less. If you rely on your dcdc to isolate don't forget that the cable to it will always be live, even when the ignition is switched off, as it is still connected to your starter battery end.
Some smart alternators require a power wire to the dcdc in addition to the main power lead, usually wired to the ignition, to tell it when to isolate etc, as the alternator voltage varies and they can switch on and off too frequently. Just make sure you read the instructions and find out what the ouput of your alternator is. Also be aware not all cable is equal. Get quality wire, especially for the long runs or voltage drop can get you.
As I said, I made up two in my camper and one in the boat, the beauty of doing it yourself is you can hunt around and get the best accessories, sockets etc. to suit what you need. Can never have enough usbs these days and I reckon a little round voltmeter is handy, just for an indication of how things are going.
Good luck with it.
PP
