Nothing like a good mux hijacked thread hey Jase!
Just driving around flat streets at 60kph in Melbourne suburbs, my MU-X seems to like to go up to 5th gear, at 1000 rpm, with enough vibration to make me sub-consciously put my foot down on the accelerator. Using the manual shifter to change to 4th gear feels more comfortable, but to me it seems only natural to shift gear only after pushing the clutch pedal!
Heheh. Same here.
Low revs in 5th produces a good deal of harmonic vibration. An overdrive lockout would be on my improvements list.
Back on topic: at 20 k Km my oil filter housing has begun to leak. Enough to coat the outside metal and attract dust, not to starve the engine.
While having a practice setup for the awning and tent for a trip next year I was surprised to find out that both the 12v outlets would not work unless the accessory mode or engine was turned on.
Seems strange to me that this would be the case, you would think that the accessory outlets would work independent of the ignition.
Why would it be setup any other way? Otherwise car manufacturers would be consciously facilitating the average idiot/car owner flattening theit starter battery? There are very, very few accessories/sockets/anything in modern vehicles these days that operate separate from the ignition. It's a deliberately designed fail-safe..
Yes, that lockout on the transmission is what causes that vibration. The 5th gear transmission direct drive is a great idea but it hangs on for too long and should cut out at a higher rpm.
I actually brought this up with a sales person a while ago when I had mine in for a service.
He asked me what I thought etc etc and when I described the 5th gear transmission lockout staying in for too long and causing a resonance all I got was a blank stare !
That used to be a problem in mine but after about 5000km the transmission sorted itself out and it shifts out of lockup in this situations. The odd time it doesn't I just press slightly harder on the pedal.
Did you buy it new? If so, that's quite rare indeed and definitely not the norm amongst 4wds.Hey! My D40 would like a word, it's got one outlet that's always powered(from factory). You can drain the battery if you want. My Waeco fridge it's set to cut the power when the voltage is low to avoid a dead battery.
Personally, I would be replacing the factory wiring, as most standard 12v cable is speaker-wire-thin! I did successfully run factory wiring for 12months powering a 60L waeco in my previous Xtrail though.Run a dual battery set up and redirect the existing wiring to the new battery.
Hahaha
Hahaha
I've been told that Rangers cig sockets are constant power also, maybe they think that MU owners are just dropping the kids at school and don't venture onto gravel roads so don't need them.
I think it's dumb on any car though as it defiantly has the potential to flatten the battery.
Old mate with the waeco, what setting is the fridge on? Have you run the battery down that far then tried to start the car on a cold morning?
Actually I have noticed too that it doesn't go into that mode as quickly as it used to, I have now got around 1900kms on mine.
mine drops into 5th and locks the torque converter at just under 80kph and will stay there at 75kph or less, if no more power is applied on a flat road . with slight power increase or load it unlocks giving the impression it went down a gear (but when put in manual it still says 5) another slight increase in power or load it drops into 4 but as soon as it is cruising with no load at under 80kph it will lock again , sending vibrations through car, a bit of a pain really.
I was getting the rumble from just below 70 with about 1200 rpm on tacho. Even towing a 2300 kg caravan it was staying in 5th at about the same rpm around 70 to 80 kph so for peace of mind I put it in manual to go down to 4th.Spoke to someone with a D Max today and he told me he has similar problem and that Isuzu told him that a computer fix had been done for the Mu-X but not the D Max.
Something to put to your service centre to see if correct.
