Mt Mia lookout
rechy
Left Kilkivan bush camp and left down Rossmore rd. Followed it down passed Threkheld rd to check out the Mt Clara smelter with obligatory photos. Then back down to Threkheld rd and turned right there. Following this road up some good climbs and low range descents. Followed this track to a Y section and kept left and followed it to blacksnake rd. I then turned left and drove for around 5-6 kms and turned right at a large stand of grass trees (blackboys) and followed that track to a trig point on top of Mt Mia (arrived). The track up has a section about 500 mtrs from the turn off where water has rutted the track a bit to make it a bit more challenging. After that the track is fine if not a bit skinny, at one section your right on top of a ridge and if you take 3 steps either way you would roll around 600 mtrs down the mountain. The view is spectacular from here. Then you can turn around up there and retrace your tracks back to blacksnake rd, where you can then explore the other tracks in the Wrattens s.f. This was a great run for a novice, as I done the section up to blacksnake rd with one vehicle then meet another couple of drivers and went to the lookout with then.
Happy travels
Dave
